im trying to locate the pin that holds the keel on a 1969 mcgrager 21 ft i need to re due the keel any help would be great thanks
Aug 10, 2020
5
1969 macgrager 21ft mgg21ft newport ore
i have a 1969 macgrager 21ft sailboat,Im need to remove the keel but cant find pi locating to remove it.If any one can help me PLEASE let me know thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Welcome to the forum!!
Try DR Marine, who sells MacGregor boat parts.
It is unclear. Do you need a replacement pin or you need to locate the pin you presently have?
Aug 10, 2020
5
both the need to be refabed and i dont want to start tearing everything uo
The swing keel bolt is most likely on the side of the keel trunk. If you don't see the bolt head then someone glassed over it. Pics would help me give a better answer but.... if you see a bulge on the side of your keel trunk then someone glassed it over. You will need to grind that off to get to the bolt head. Then it is simply a matter of unscrewing the nut. The pin is nothing special. Any fasterner shop (McMaster Carr) can supply you with a high quality stainless bolt of the right diameter and length.
Aug 10, 2020
5
ok thank will look again
