Jerry with the Mac is there a reason you just didn't drop the tongue down and then block the back and then raise the tongue all the way up and block the front? Most of the guys with Mac 26 S's and D's do that.In putting the 26D up on blocks.........--jerry
An object will fall 2 feet in .250 seconds. If it weighs 4 tons and you happen to be underneath, you will die! This is becoming a game of "you bet your life". Don't try to do this in a make shift fashion! Use the best material and don't compromise anything! Stu Jackson broke his leg last winter and didn't get out sailing for the entire season. After they lift a boat off your legs how long will it be before you can walk let alone go sailing?Lower the bow. Use old tires (free) with a beam across them and one more tire each angled on top of the beam to the curve of the underside. Lift the bow on the tow jack. Support the bow with a strap under it anchored to two A frames each side with the A frame leaning against the gunnel. Rope base of A frames along the ground to prevent slipping.
Take the wheels off the trailer and pull it out on the hubs. Support the bow with tires and beam like the rear. Place further tires around the boat for safety. If the boat is as heavy as you say fill the tires with dirt or sand. It makes each tire a 200lb brick.
Mic Jones
Woody floating the boat is the way I fixed my Mac25 bunks. Its about 45 mi. to the launch and I don't want to drive the frwy with all of their post earthquake dips with broken and rotted bunks. The bunks on the Mac broke when loading the boat, so floating it was not an issue. Adding supplementary bunks on a 2700# boat would also be doable, but this old gal weight almost 4 tons.if yhe boat will flote just launch it ....tie it off...go fix the trailer....come back and reload the boat back on the trailer ....unless you had planned to do some other things to the boat while off the trailer .......in that case get a boom truck and slings and unload the boat ....it is not worth getting hurt just to save a dime even on a tight budget.....
good luck with your work ...and be safe ...after all it is supposed to be fun
regards
woody
