Since you bought a 9.9 Tohatsu electric start, jsut a couple notes. The Nissan and Mercury 9.9 were built by Tohatsu so parts are interchangable should you not be near a Tohatsu dealer when parts are needed.
Years ago when the motor trolling plugs were improved, I started using them for motor hookups as they will work nicely since they can handle when drawing the amperage when starting the engine.. Make sure the red line is attached to the postive or plus side of the battery and the black is connected to negative side of the battery.
For those of you with a two battery system, never change the battery selector while the enginge is running or you could destroy the charging unit in the motor.
Crazy Dave
Crazy Dave
