Identifying Bearings no-name Catalina 22 trailer
ShawnL
Jul 29, 2020
235
Catalina 22 3603 Calumet Mi
Finally launched my Catalina 22 today (had to re-core the cabin top). Unfortunately, I destroyed a wheel bearing on the way to the boat launch. The launch is only a 15 minute drive from the house. Didn't notice anything weird (noise, etc) until we were pretty much at the launch. Decided to get the boat off of the trailer (we keep it on a mooring) since we had people with us to help, etc.
Now I need to figure out what to do about the trailer. It's still at the launch (not in the way, but it can't stay there). I can't find any markings on it for a manufacturer, etc. I'm sure it used to have some, but neither I nor the PO could find any when I bought the boat. Take the tire off, pull what remains of the bearings out and take them to an auto parts store? No trailer stores around, but a kind person at the boat launch mentioned that the local auto parts store had a lot of trailer bearings in-stock.
Likes: Timm R Oday25
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
Think that you are on right track. Remove tire & hub. Cleanup hub & remove bearings. Take old bearings, seal, & hub to auto parts store to match bearings & seal. After cleaning bearings & seals, you may be able to see bearing manufacturer & size / part number inscribed on bearing race. Repack bearing with grease & reinstall. Two to three hour job including trip to auto store! When you verify that your repair is successful & get the trailer back home, best to replace bearings on remaining wheel before trailering boat again. I have always used “bearing buddies” on my trailers. Many claim that they really don’t help; however, at least it permits you to periodically add fresh grease into the hub. In all the years I have launched in salt water, I have never had a bearing fail, so I feel that they help.
-na -NA Anywhere USA
You will probably need the 1.98 bearings with matching racers. Some refer to the bearings as 2 inch.
Bearing Buddies are covers with a grease fittings which are great to have as @BigEasy pointed out
Lastly use grease compatible with water
Likes: BigEasy
Jun 21, 2004
3,225
One has to read & follow instructions carefully when using “Bearing Buddies”. If you put too much grease in the hub, it over pressurizes when bearings & shaft heat up, & seals will dislodge. I believe that is the reason for negative reviews. There are detailed instructions on how much grease to add to the hub, for bearing buddies to perform properly.
SCA (Welsford) SCAMP SCAMP 3 Newberry FL
Can't speak to off-brands/clones, but genuine Bearing Buddies only pressurize to 2.5 psi above ambient. It only manages that much, due to the spring piston on the outer side of the Bearing Buddy. If you attempt to over-pressurize it, it causes excessive excursion of the spring piston and exposes an over flow port, that the grease flows out of. It takes far more than 2.5 psi, to dislodge an inner seal.
Hope this clarifies,
Charles Brennan
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
If memory serves me correctly, Reese brand bearing savers have a hole to prevent overfilling
Sep 25, 2025
3
Starwind 190 Minnetonka
I'm doing this very same job on the trailer of my 'new' old boat I just bought. 86 Starwind 190
Bad bearings will ruin your day before it starts. :facepalm:
You should be able to read the numbers on the side of the bearing surface (etched on the side of the inner ring of each bearing, not the cage that encircles it). Once you identify the bearing, it will have a matching race (the part that presses into the hub). Make sure you look at the seals as well. The numbers are usually imprinted on the exterior surface of the rubber seal. If you cant find it or it was damaged, you'll have to use a micrometer and measure the ID (axle surface where the seal rides) and OD (inside the hub where the seal seats). NAPA or any good automotive store will help you find what you need. If you can read the numbers, type them into google and you'll find the kit you need. As mentioned previously, make sure to use waterproof grease and do both sides :)
Ringo
Sep 25, 2025
3
And judging by your photo, you're likely going to have to clean up the axle surfaces with some emery cloth due to the rust (no bearing cap on the hub).
ShawnL
Jul 29, 2020
235
There was a bearing cap on there when we left the house (5 miles pre-incident). It actually caused a lot of damage to the spindle as well. Trailer is currently at a local mechanic.
