My Catalina 27 project is in an awkward place. Let's' just say it was a REAL good thing I found this latest issue on the hard!
I decided to pull my prop shaft the other day after noticing that the shaft hose was installed on the packing gland and stuffing box with two, (only two) very hinky clamps. So I dropped the rudder, disconnected the shaft coupling from the reversing gear, (Atomic 4 motor) and pulled the shaft.
You can see the results on the last page of my "living thread" that is documenting the ongoing refit and refurb of my '75 C27. The thread can be found here: http://forums.sailboatowners.com/index.php?threads/c-27-refit-refurb.123450/ Just go to the last page, currently page 19 for pictures of the disassembled assembly.
The issues are:
* The shaft coupler came off pretty easily. I was able to pop it loose by hopping out and giving the prop and shaft a couple of good tugs. The set screw bites on the shaft tell me it has been on and off several times. There are set screw bites in a few places up and down the shaft. There is also what best can be described as a slot that was created by the set screw, as if the shaft had been moving in and out roughly 1/2" with the application of forward and reverse thrust... !!!
* The bronze prop shaft itself has some scars, particularly where the packing material has worn on it. The diameter of the shaft is down .015" and has some grooves right there. It also has some discolored areas where the shaft looks more copper than bronze.
* I already have a pound of Ultra-X to repack the stuffing box but I am concerned about the shaft wear. A dripless seal system would remove the wear concern and provide a fresh new seal surface, but my fear is the prop shaft is too far gone to try to re-use.
At this point I am pretty taken aback. I am handy, I can do the work, but I do not want to take any shortcuts, intentional or otherwise, and I do not want to make any mistakes. I do not want to lose the boat while I am away from it and I don't want it sinking under me; particularly if my family is with me!
The ideal thing will probably be new hose, new clamps, new dripless seal, new shaft and fitted coupler. I just want a gut check to see if I NEED to to this total replacement or if it is more of a WANT on my part...
All comments will be appreciated!
The issues are:
