Hi All,
I've ran into an issue that I need some advice on how to address. For the pass year I've been trying to track down a small occasional leak in my Hunter 25 v-berth area. This weekend I believe I have finally located the leak.
It appears the water is entering from a previous unknown repair from what I can tell. I believe the area is just above the water line, since the water only appear during choppy weather when docked. The hull was cleaned and inspected about two weeks ago with no major or minor issues being reported. There is also no visible sign of damage that I can see above the waterline from the outside on the hull.
My question is can this be repaired without pulling her out
The closest dry dock is about an eight hour sail away.
The attached pictures below are looking up from the bottom of the hull.
Does anyone know how thick and what the construction of the hull is above the waterline for a 1974 Hunter 25
