I Need a Halyard Exit Plate
Jim Schaff
The halyard exit plates on my 94 H26 are plastic. There are two of these plates -- one for the main halyard and one for the jib. My main halyard exit plate broke off, so I decided to replace both plates. I found an SS exit plate in the West Marine catalog and ordered two of them but they are way too big. I would have to really widen the slot in the mast for them to fit; so much so I'm afraid it would significantly weaken the mast. Any ideas where I can get a halyard exit plate to fit the existing slot in the H26 mast? Jim Schaff s/v Savannah
Rick Webb
I Think You Have a Zspar Mast
Try thes guys: http://www.usspars.com/
G
Gerry Cooper
Z spar mast bits
Jim, I had the same problem with my plastic exit plates. Ordered Schaefer SS replacements which were totally wrong. Found the right bits at www.rigrite.com
Dick Carey
Rigrite in RI is a good source
You can contact Rigrite in RI. They are a good source for parts for the Z-Spar masts. Ihad to replace one on my H-33.5 and the had it in stock. It fit great, including the hole allignment for the pop rivits. If you don't already have one (and I didn't) you will have to buy or borrow a poprivit tool to install. You DO NOT want to fasten with screws and have the screw ends sticking thur to snag and damage halyards. Dick Carey S/V Puffin H-33.5 1990
C
crazy dave
z spar mast
You have a z spar mast. Z spar screwed up some years ago but you can get the part from USSpars. Ask for Julian and he will help you.
Jim Schaff
Thanks Guys
Thanks for the info. I haven't had a chance to measure yet but it looks like the halyard exit plate from US Spars, Inc. is exactly what I'm looking for! If that isn't it, I'll investigate a little further into rigrite.com. I do have a pop rivet gun and will use it for this replacement project. I have used SS screws in my boom to add E-Z Jacks, but I cut the screws off and rounded off the ends to make them nice and smooth -- not an easy job! Jim Schaff s/v Savannah
C
Crazy Dave Condon
same masts
To make a long story short, Z spar makes good products. However, they goofed some years back and I believe there may be some creditors looking for them. They are no longer in the US. US spars is basically Z Spar product. Therefore, you will get the right part and Julian can help you.
