Took off the wood piece on top of the centerboard, (I sanded part of it before I decided to do it right and remove hardware).
Using solvent to clean the grime, remove weak epoxy repair spot, clean out deeper scratches. Lots of shop vac action. I removed both windows and scraped a lot of white silicone caulking from everywhere (pretty sure that's not the right application for that
Looks like there was the same white silicone caulk all along the metal rail where the outer hull meats at a seam with the cabin (has a rubber bumper in the rail) its smeared all over top and underside of the rail, and I'm starting to scrape that out. Will post pics of that too eventually.
Pretty close to the point where I can start experimenting with fiber glass and epoxy. Ive been educating on process and methods via YouTube. I think ill start on the transom repair so I have more experience when I get to the centerboard repair (and then on to underside repairs-not to bad but ill definitely be asking some opinions, as its gonna be under water/potentially exposed to beach/lake bed contact.
Hope everyone had a good Memorial Day weekend!
