- Dec 27, 2009
- 82
Never tried the prewash method before. Sounds like a good idea. I live in Nevada where the moisture/humidity is nil. What Mildew? Too old smart, too late rich Fair Winds and Full Sails....Regarding the pool technique: I lay the sails out on my lawn, wet them down, scrub both sides using a soft brush and laundry detergent, then toss in my pool for about an hour right after shocking it. The 25 year old sails clean and brighten up nicely, and the mildew is gone. This is the 14th year I've done this with the original sails, so wasn't too worried about hurting them and I don't race anymore. So far so good.
Would a "plastic can" or metal can be preferable??We soaked ours in Oxyclean in a clean trash can and they came out like new. I think I had to use about 1/2 of the container mixed with water. It works well for clothing and it will not hurt the sails. Do not get Oxyclean mixed up with bleach, they are 2 different things. If you have bad stains you can spray the stains with the Oxyclean spot remover first.
You'll have to ask Thinwater ... see posting #5 in the sequence. Its his quote.RichH...looking at a reply to your first post...Help me with the term "rational environmental law"
If you read that sentence VERY carefully, it's ok. He said that if people were smarter and more sane, we would have "more rational environmental law." He definitely didn't say our environmental laws are rational, and he only said they would be "more rational," not necessarily completely rational.RichH...looking at a reply to your first post...Help me with the term "rational environmental law"
I had posted something longer, but shortened it to this. I spend part of my time working on enviromental regulations, from both sides. The reasoning is almost always based upon prior regulations, politics, and precident, and seldom on science. The science is only used to support the rhetoric.ra·tion·al/ˈraSHənl/
Adjective: Based on or in accordance with reason or logic: "a rational explanation".
Yup.I though Sunbrella was Acrylic fiber.
When I sewed mine on last spring, the vendor who sells to all of the awning companies in the area recommended that I use nylon thread .the cost was about 60 dollars compared to 500 dollars at a local loft .Yup.
But since it is the polyester stiching that fails first, Rich was partly right. As we all know, most things made with Sunbrella can be restitched 2-3 times before the fabric goes, though it will fade a bit.
What I really dislike--though it looks good--is the use of sailcloth or other thin polyester materials as a sacrificial cover on rollerfurling jibs. It sacrifices itself within a few years and is expensive to replace. Sunbrella or the equivalent is the thing to do; i will last as long as the sail, stitching not withstanding.
