So, I will freely admit that boat electricity is not my strong suit.
But last year, I (finally) replaced my (2) Group 31 batteries with (2) 6-volt GC batteries. The delay was, in part, because I wasn't sure how to wire them for 12 volts.…I said boat electricity is not my thing.
My boat had no fuse at the battery bank, so over the winter, I installed a fuse at the battery…
I worked on the boat over the winter, and no issues with the DC power (but no real loads in it…just some lights on).
Today, I launched Tally Ho in 45 F temps.
Once in the water, but still in the slings, I tried to fire up the trusty Yanmar 2GM20F. She turned over, but didn’t fire right off the bat. I stopped pushing the button after 20 seconds, took a beat or 2, and them pushed the start button again…she turned over, but then stopped. And no alarm from the control panel…
Went below, and my battery monitor was not reading any voltage, analog VM in the panel didn’t move…
Then it dawned on me…I bet that “+%€¥£€^[ fuse blew. Sure enough, I removed the fuse and connected battery cable direct to the battery, went back to the helm, turned the key on, got an alarm tone, hit the start button, fired up the Yanny and moved her to my slip.
So, my question is what size fuse should I use ? The one that blew was 100 amps. I have (I think) 2 AWG wire from the battery bank to the battery switch.
So was my fuse too small (200 and 300 amp fuses were also an option, but I ordered with the 100 amp fuse)…or do I have thing else (worse) wrong in my engine starting system that killed a fuse that should have been OK for this small system?
Give me a quick education so I can order a new (correctly sized fuse)!
Thanks,
Greg
Thanks,
Greg
