How many of you have lost your favorite hat while sailing? A number of years ago I almost lost mine while sailing off Fort Myers, FL. It is the same one I’m wearing in the picture that is on the front cover of my book so obviously I retrieved it but it wasn’t easy and the reason was I had difficulty stopping the boat. I was OK sailing forward but stopping within 6’ or less of a target was not my best move. Since retrieving a hat is one thing, it is nothing compared to a man over board situation but with the hat pick up all I wanted was a quick “stop and go” so I decided to figure out the simplest way and the following is what I came up with.
I needed to position the boat so the wind could not fill the sails. You might think that position is head to wind with the sails luffing but it isn’t. The boat will definitely stop when positioned head to wind but the skipper has little control in that position. Here’s the problem with head to wind – you have to be right on and stop exactly at the hat. If you’re off by a few feet it is hard to get the boat turned away from the wind and sailing again. Each time they try it they have to exactly hit the hat and it isn’t easy.
My method is to sail toward the hat on a close reach. As I near the hat, I let the sails luff gradually to slow the boat so I’m controlling the speed and direction. The pick up point I’m aiming for is on either side of the boat. A quick luff and the boat stops. Then grab the hat and trim in and off you go.
Suppose I stop short? I just trim in a bit and ease up to the hat.
The ability to stop a boat on a dime has a lot of uses and should be practiced before you really need to use it.
To solve the hat problem, I always wear a hat clip and that has saved my favorite hat many times.
Any hat stories out there?
