Hurricane Michael old Invest 91
JamesG161
Feb 14, 2014
8,074
Hunter 430 Waveland, MS
We have be seeing this potential for a few days now. Heavy topical moisture in the warm South Caribbean is alive and well.
____
Invest 91 appears to be close tracking to the earlier TS Gordon.
In will be fast moving, but should be watched closely.
The Gulf of Mexico is still warm.
We will know much more, when the first Hurricane Hunter flight explores Invest 91.
They will probable fly late Monday the 8th, when it enters the Gulf off the Yucatan.
Dammit Jim...
PS: Tracking by ECMF model is shown to affect Gulf coasts of LA, MS, AL, and FL
Jun 21, 2004
3,176
Beneteau 343 Slidell, LA
Here we go again! Just put the genoa back on the furler this past Wednesday, following the TS after Labor Day.
Looks like summer and storm season will be around a bit longer. I actually planned on hauling out the boat, this morning, for routine bottom work; however, I postponed it until next weekend because of the high probability of rain for several days with the approaching low pressure system.
JamesG161
Feb 14, 2014
8,074
I just cleaned and protected all my Dodger windows. Was going to put them back Monday.:rolleyes:
If you use the nice weather app above, NOAA indicates in Gulfport MS, 20 knot winds early Wednesday morning. Barometric Pressure dropping Tuesday.
If that is true, discounting the rain, nice sailing time.
I am waiting on the next ECMF model run.
Dammit Jim...
JamesG161
Feb 14, 2014
8,074
It is looking like TD #14 will emerge between the Yucatan and Cuba. ECMF model has it being sucked in behind the HIGH pressure system centered over the Virgina's now. This High is fast moving and so will be TD #14
This storm may get sucked back into the Atlantic.
Dammit Jim...
1,293
Catalina 22 Pensacola, Florida
NHC already had it named as Micheal and will be hurricane at landfall in northern gulf probably at big bend area of Florida Panhandle.
JamesG161
Feb 14, 2014
8,074
Micheal
The Hurricane Hunters are in the Storm now. It is a low level flight
Unfortunately, there is a eye beginning to form. Winds are in the North Eastern quadrant, peak 50 knots.
This area still has a lot of Solar Heat build up. Fast moving is what we need.
The latest ECMF Model shows a Gulf Coast hit is 96 hours.
The movement of that HIGH pressure now suggest a curve back into the Atlantic too.
Hurricane winds, if at all, will be on the South East part of the storm. Why?
Cuba will shear the winds on the East.
Dammit Jim...
JamesG161
Feb 14, 2014
8,074
HH's flight done.
The Reds are near Hurricane winds.
Note the tip of Cuba in upper right of Image.
Dammit Jim...
JamesG161
Feb 14, 2014
8,074
The big HIGH that was over Virginia over the weekend is the BIG dog.
Not only is it Pulling Michael behind that front, it is also responsible for Pushing Leslie, finally, toward Europe and Northern Africa.
Northern Florida is on the path by ECMF [model not shown in NOAA models].
Dammit Jim...
PS: Hurricane Hunters, who are getting the only detailed measurements, are on Mission #3 now.
JamesG161
Feb 14, 2014
8,074
Michael
is very compact and moving fast across the Gulf.
This is a NOAA data buoy the direct path and has a CAMERA too.!
https://www.ndbc.noaa.gov/station_page.php?station=42003
It might give you an idea of what sailing in a Hurricane might be like.
The water depth under this buoy is 10,663 feet. This a lot of Anchor chain!:yikes:
Wave height with just ≈35 knot steady winds.
:yikes::yikes:
____
The Hurricane Hunters are flying out of Keelser AF in Biloxi so they are making many flights. Mission #9 is in the storm now.
This is #8 which shows N and NE as the storm surge side of Michael.
Tight small eye wall area with 968 mb as the eye center. [not always the Space view spot]
Notice in the lower right 046 SHIP, that is a approved data station Ship that took safe harbor in Cuba!
Northern Florida braces for Michael.
Dammit Jim...
JamesG161
Feb 14, 2014
8,074
Nice link Gunni. You can see the High pressure over Nebraska pushing it back out to Atlantic.
____
Michael's Eye wall tightly compact. HH's show most of the 60+ knot winds on the Eastern Half.
Here is the Panama City Beach NOAA data station.
https://tidesandcurrents.noaa.gov/stationhome.html?id=8729210
Michael will go back into the Atlantic on Friday.:(
Dammit Jim...
