Hurricane Irma & TS Lidia
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
Finished with boat prep but not hopeful it will survive. There are too many snowbird boats not prepped at all. After seeing what a cat 4 can do there is no way my boat will make it through a cat 5. Wife and 96 year old mother are bugging out. We did Charley not going to do Irma. Good luck to all.
Gunni
Mar 16, 2010
5,937
Good to hear. What are your options for a haul and block? Pretty much everything down that way is low. Still have a few days. Good luck, stay safe.
Just heard from kin in Naples are - they are headed for the Georgia hills with the kids and pets.
WayneH
Tartan 37 287 Pensacola, FL
Taking off Friday morning for the 14 hour drive to the boat in P-cola. I need to take down the sails and bimini and maybe the solar panels, too, this time. The boat is storm ready for a squall line or a microburst but nowhere near ready for the edge of a Cat 4. It looks like the eye will pass to the east of my boat but the tropical storm winds extend too far out to ignore.
Sep 2, 2017
14
Kenner Kittiwake Savannah, Ga.
My boat is tied down to it's trailer while I do touchups, is there anything else I should do to prepare?
Beneteau 323 Annapolis MD
How about putting a tarp in the cockpit and flood it to weight down the boat?
Sep 30, 2013
3,719
I was thinking about sledgehammering some 2x4 stakes into the ground, and "mooring" to them. Maybe even take the wheels off the trailer, if things look ugly enough.
Kermit
Jul 31, 2010
5,722
If you think the weather is ugly, you should see the dancing girls!
Feb 20, 2011
8,062
One casualty in Bahia San Carlos due to Lidia.
Met the owner while he was starting his salvage ops, said he was on his brand-new mooring. Three 5/8ths 3 strand mooring lines were sawn through. Guess his chafe gear wasn't up to snuff, and he wasn't aboard at the time.
He was pretty philosophical about "$40,000.00 down the tubes".
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
I bought for $10 from local Rental Equipment Store, a used 2.5" x 50' fire hose. I have cut out 4' pieces to run my lines through, using the heavy duty fire hose as the chafe guard [uninstalled but ready;)]
______
As of noon today EST, this is NOAA five day forecast that has shifted a bit eastward versus post #14...
____________
This is what @Gunni said in his post #11 last Sunday. Irma will run into the 100 mph East bound Jet stream, a little late for Florida, but the driver for the North turn.
Good Luck to all!
Jim...
pateco
Aug 12, 2014
2,207
Looking worse, and I cant cross tie and block my canal until Friday
Jan 24, 2017
672
Hunter 34 Toms River Nj
Here In the north east I have tied pieces of carpet between old car tires to both sides the hull as fenders. The tires are placed the full length of the boat with out any gaps between the tires. Then placed one tire tube fully inflated under an old truck tire, then place both over the top of the piling as a heavy duty fender. Also added more dock lines and adjusted them for storm surge along with removed all sails and anything to reduce effects of wind.
We also hooked up 2 additional temporary bilge pumps to two separate batteries and suspended the batteries high from the ceiling in case of a hull breach. My thoughts are if the main battery shorts out I have 2 back up pumps. Note I used smooth hose instead of currugated hose, this increases flow rate.
Weathered quite a few storms this way and so far have been quite lucky, just had to remove a few black marks from hull.
JamesG161
Feb 14, 2014
8,105
Hmmmm very clever. A Floating piling fender!
I assume the line allowance for the Storm surge will not put your hull over the top of the piling. Making the piling a spear.
Sounds like your boat has, the padding like on a boxing sparing partner. Taking most of the punches.
Good luck...
Jim...
AXEL
Mar 12, 2008
359
Catalina C30 MKIII WEST ISLIP, NY
In prep for Sandy (here up North) I strapped 4" x 4" x 12' (4 of them) to the pilings at my dock. Strapped them using racheting straps and tied them together with rope. Covered them in carpet. They were very secure and would not move. These guys kept my boat (C30) from coming over the dock during the wind and storm surge. Saved my boat.
