Hi folks, I just bought a 35.5, the bilge is clean and dry.... I want to use the shower at some point, and would like to run the drain into a small sump so it doesn't pollute the entire bilge. I ran some water down the drain, and determined that it drains somewhere below the liner, then runs into the main bilge thru the limber hole. What have past owners done? There must be a fix for this....
TIA
Rich
TIA
Rich
