Hunter Legend 35.5 shower drain
Jun 4, 2024
30
Hunter Legend 35.5 Charleston SC
Hi folks, I just bought a 35.5, the bilge is clean and dry.... I want to use the shower at some point, and would like to run the drain into a small sump so it doesn't pollute the entire bilge. I ran some water down the drain, and determined that it drains somewhere below the liner, then runs into the main bilge thru the limber hole. What have past owners done? There must be a fix for this....
TIA
Rich
Jun 1, 2009
1,813
Hunter 49 toronto
TIA
Rich
My absolutely best recommendation is the Whale IC pump . You will never regret this choice
Pm me if questions
Jun 1, 2009
1,813
Hunter 49 toronto
DYFLWD
Feb 20, 2016
54
Hunter Legend 35.5 Lake Texoma
The box would have to fit in the bilge area, not sure if it would. Have to measure. The Whale pump is submersed? How do it work?
Jun 1, 2009
1,813
Hunter 49 toronto
There is no sump box.
It’s a pump with a smart sensor on a T fitting
go to the whale site. It’s all there
Likes: DYFLWD
