Bob, We own a 2004 386 LE. We like the top opening refrig/freezer (Adler Barbour), as it keeps the cold "in the box". The freezer will actually freeze water over night for ice - even at less than max settings. Overall the 386 is a very comfortable boat. The 16K BTU air conditioner works great too.
In hindsight, I don't think I'd have gone with in-mast furling mainsail (loss of of sail roach/sail area). Neither the B&R rig either, as it limits you to a 110% genoa (fairleads are on coach roof and sheets run between the shrouds - genoa and sheets can only extend so far aft). Given the sail setup though, she sails OK for a cruiser (I'm not a racer either). My biggest disappointment in the 386 is that she was built as a limited edition boat (a transition to the 38 and 380), as a result Hunter doesn't maintain much in the way of replacement parts, how it was actually put together or anyone who knows much about them at this point in time. You're on your own with this boat and Hunter.
We do like the aft cabin room, separate toilet/ vanity accommodations, forward vanity and galley setup. Our corian countertops were improperly installed and we had to have a major crack repaired. The teak bulkheads and surround are actually teak and not some plastic look-alike that Hunter is starting to use. The teak and sole look fantastic.
Battery design is deficient on the 386 with only 200 amp hrs (one 4-D battery). Better to replace the 4-D with four Group 31s and up the amp hrs to over 400. We have a 130 watt (7.39 amp) solar panel and a generator (35 amp) on-board, so power is not a problem for us. However, without them, the basic boat would be short basic electrical needs.
As we've gotten into the boat, we find too many shortcuts from Hunter. Poor workmanship, design flaws and areas they cut corners rather than having done a proper job. Look under coach panels for sanded away resin leaving the core unprotected, no backing nuts on critical deck gear, uncaulked deck fittings, wiring that should have been run through installed PVC duct pipe, poor access to filters and thru-hulls, use of the least expensive and marginal hardware for the intended job (undersized running rigging lines, plastic vs bronze strainers, improper thru-hull matches at seacocks (NPS and NPT on same fittings!), screws cut off, rather than using ones of correct length, and the list goes on.
Check your boat carefully, before purchase. Many of these things are personal and not critical or safety deficit. Hunter is a production boat, not a custom yacht.
We've done a lot of improvements on our boat for comfort and safety (and personal desire). It sails nicely, takes rough seas easily and is large enough for many people on board. Nice boat for the money regardless.
