Hunter 386 LE or Hunter 38
5
Hunter 38 Bradenton, FL
The features of the 2004 Hunter 386 LE are appealing due to the forward vanity, separate refrigerator and freezer, and aft storage. In 2005 the Hunter 38 changed the hull design, and added Flexi-teak in the cockpit and transom, but eliminated the forward vanity and one aft closet. They subsituted the Norcold Refrigerator/Freezer for the traditional refer and freezer.
Is the Norcold refrigerator unit a worthwhile substitute?
Any problems with the Flexiteak?
Does the Hull Design add significantly to performance?
We have always been impressed with the help received on these posts and look forward to your insights.
Thank you.
Bobby Di
Apr 6, 2007
54
Hunter 38 Owen Sound, Ontario
I have a 2005 Hunter 38 and have been really pleased with the Norcold Fridge and Freezer. Our previous Niagara had the usual nautical Adler Barbour refridgeration holding plate set-up and I was like you a bit sceptical about the new Hunter set-up. My primary concerns were with possible lack of insulation and "all the cold air" falling out of the units when opening the doors. Anyway we have 4x 6v Trojian house batteries in the battery compartment (additional 12 starter battery) and have no problems for a couple of days at anchor without charging. Compared to having to pull half the food out of our previous fridge to get to that last bottle of wine we love the ease of access of the Norcold units. Friend that's a lot more mechanically minded noted that there's not much "heat energy" in the air that is lost on opening the door as air cannot hold much heat.
Really don't know anything about the 386, but I can highly recommend the 38. Really great boat to both sail and live with.
Oct 7, 2008
5
Hunter 386 or Hunter 38
Thank you Gordon. That is just the kind of info I was searching for. Am I to assume that you have separate Refrigerator and Freezer units or do you have the single refrigerator/freezer Combination? If so, is the freezer space adequate?
BTW, any problems with the Flexi-teak on the cockpit seats and sole?
Bob DiSab
Sarasota, Fl
Apr 6, 2007
54
Bob DiSab
Sarasota, Fl
Hi Bob,
We have the separate fridge and freezer. I would think that space would be might be an issue with the combined unit. We often use our freezer, at warmest setting" as an additional fridge for "beverages" to give more room in the main fridge. Certainly there are lots of options. We can leave home port with both units on, cold and filled with food. As food and batteries get depleted we turn off the freezer and move everything into the fridge. We have had no problems with the flex teak. Still looks like new. We have 2 border collies and I was worried that their nails were scratching the surface. All they were doing was removing dirt from the surface and the scratches quickly weather to match the rest of the surface. Quite good as non-skid and very comfortable in bare feet.
Gordon
Oct 10, 2008
277
Catalina 445 Yorktown
Bob, We own a 2004 386 LE. We like the top opening refrig/freezer (Adler Barbour), as it keeps the cold "in the box". The freezer will actually freeze water over night for ice - even at less than max settings. Overall the 386 is a very comfortable boat. The 16K BTU air conditioner works great too.
In hindsight, I don't think I'd have gone with in-mast furling mainsail (loss of of sail roach/sail area). Neither the B&R rig either, as it limits you to a 110% genoa (fairleads are on coach roof and sheets run between the shrouds - genoa and sheets can only extend so far aft). Given the sail setup though, she sails OK for a cruiser (I'm not a racer either). My biggest disappointment in the 386 is that she was built as a limited edition boat (a transition to the 38 and 380), as a result Hunter doesn't maintain much in the way of replacement parts, how it was actually put together or anyone who knows much about them at this point in time. You're on your own with this boat and Hunter.
We do like the aft cabin room, separate toilet/ vanity accommodations, forward vanity and galley setup. Our corian countertops were improperly installed and we had to have a major crack repaired. The teak bulkheads and surround are actually teak and not some plastic look-alike that Hunter is starting to use. The teak and sole look fantastic.
Battery design is deficient on the 386 with only 200 amp hrs (one 4-D battery). Better to replace the 4-D with four Group 31s and up the amp hrs to over 400. We have a 130 watt (7.39 amp) solar panel and a generator (35 amp) on-board, so power is not a problem for us. However, without them, the basic boat would be short basic electrical needs.
As we've gotten into the boat, we find too many shortcuts from Hunter. Poor workmanship, design flaws and areas they cut corners rather than having done a proper job. Look under coach panels for sanded away resin leaving the core unprotected, no backing nuts on critical deck gear, uncaulked deck fittings, wiring that should have been run through installed PVC duct pipe, poor access to filters and thru-hulls, use of the least expensive and marginal hardware for the intended job (undersized running rigging lines, plastic vs bronze strainers, improper thru-hull matches at seacocks (NPS and NPT on same fittings!), screws cut off, rather than using ones of correct length, and the list goes on.
Check your boat carefully, before purchase. Many of these things are personal and not critical or safety deficit. Hunter is a production boat, not a custom yacht.
We've done a lot of improvements on our boat for comfort and safety (and personal desire). It sails nicely, takes rough seas easily and is large enough for many people on board. Nice boat for the money regardless.
