Hunter 33 2006 with Yan Y3M30 overheating
17
Scott B said:
We bought our boat when it was 2 yrs. old and had the 3 blade Vari-Prop which was optional when it was new. I still have the 2 blade stock prop as a spare.
I get 6.5 knots at 2800 and will get over 7 - 7.5 at 3600 wide open.
Yes you should cruise at 80%, but occasionaly ramp up to wot for 10 min. to clear the carbon from the engine. ( from the Yanmar manual. )
The 3YM30 29 hp was part of the Mariner Package and was an upgrade from the base 3YM20 21 hp.
What is the diameter and pitch of the vari-prop which you have?
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Off hand I have no idea. I can check the manual I have on the boat this weekend and see if it's there, otherwise will be late Fall when we haul out before I can measure.
I do know the pitch is adjustable and is set when it is installed.
May 24, 2011
81
Marlow Hunter 40 Oriental, NC
This is a known problem with this engine. Unfortunately, Yanmar makes everyone have to figure it out themselves before resolving. I got mine fixed back in '07...Yanmar did cover parts AND labor.
JohanB
Jun 28, 2012
8
Hunter 33 West River
Yes - I ordered mine new with the engine upgrade at 30hp; the 19hp was the standard as you indicate. With a clean prop and bottom at 3000 rpm I average 6.25 knots. She doesn't get up to 7 knots at full tilt under power in flat water. But with a running swell she has gone over that. At max rpms she gets up to 6.85 knots. My most recent readings are faulty since my log sensor has gone bad. I need to replace it - any idea if that is difficult to do?
Johan
