I've had this boat since new (2006). The engine has 440 hrs on it.
When I travel at max throttle (3650 RPM) for more than 5 -10 min, the coolant over temperature alarm goes off. As far as I can tell, it's always been like this (but I didn't run it above cruising speed until about 1 year old). At cruising speed (3200 RPM) it can run perfectly fine all day.
I changed the raw impeller and checked out the fresh water pump. I changed the thermostat but it still overheated. I just installed an actual temp gauge (previously only an alarm), and it verifies that the temp really is high when the alarm goes off. I took the front end off the heat exchanger and everything looks OK. I haven't taken the heat exchanger core out yet, because the back end looks fairly inaccessible.
I used an infra-red thermometer to measure the exhaust manifold. As it leaves the engine, it's hot - over 400 deg F but downstream of the point where the raw water mixes in, it's only warm - between 80 & 100 deg F. I don't know specifically what these temperatures should be, but my values seem reasonable. The visible part of the rubber hose leading from the mixing tube to the muffler seems in great shape - no sign (at least no external sign) of damage.
Has anybody with the same boat or engine seen this problem? I don't know if most people run their engines at max throttle. Could it be that it's a design problem that most people don't notice?
What would you experienced folk suggest I try next?
Help really appreciated!!
