Hunter 306 Head Head Liner
Jun 25, 2004
615
Hunter 306 Pasadena MD
Not sure what to call this: the head liner in the head? Has anyone with a Hunter 306 (or maybe related models from close to 2004) ever removed the hard pan that lines the overhead part of the head? I'm worried about a possible/probable deck leak dripping on the top of the head liner, and wondering how to get it off or even if it's possible.
Jan 4, 2006
7,760
Not at the boat right now but it seems to me I ran some wiring through here decades ago. This assumes the hard ceiling head hasn't changed much between my1999 and your 2004 :
A closer shot of the entrance :
You want to open that up to ensure it's ultimately dry up there. You will not access that area as all work is done on the exterior of the cabin roof.
Are you thinking the leak is through one of the machine screw hole(s) in the genoa track ? I'm guessing that anything fixed to the cabin roof is machine screwed into threaded aluminum backing plate(s) on the underside of the cabin roof and just above the hard ceiling.
Slow picky job but can be done if that's the source of water ingress into your head. Maybe into your boat's head too :biggrin:.
