Hunter 260 Versus Seaward 26RK
Tedd
Jul 25, 2013
779
TES 246 Versus Bowser, BC
We currently sail a Macgregor 26S. We're going to upgrade to something roomier in a year or two, for longer trips, but we would like to stay with a trailerable boat. There are a few options but the two that stand out as being within our price range (depending on the year) and a significant step up from the Macgregor are the Hunter 260 and the Seaward 26RK. I know these boats are in some ways not directly comparable. For example, we're going to pay more even for an older Seaward. But, based on what I know so far and what our priorities are, I came up with the comparison below. I'm interested in Hunter owner's thoughts on this. Do you agree with my assessment? Thoughts on the factors I haven't rated? Other things I should consider?
FactorHunter 260Seaward 26RKAdvantageComment
Aftermarket SupportExcellentPoor260
Ease of Launch/RecoveryGoodGood260
Ease of ResaleVery GoodGood260
Ease of RiggingVery GoodGood260Expect mast handling to be easier on 260
Interior Light/PortlightsVery GoodGood260
Interior SpaceExcellentGood260
Purchase CostLowerHigher260Depreciation might not be that different
Tow VehicleSUV or PickupPickup Only260Allows us to have one vehicle
Towing Weight4,800 lb6,000 lb26026RK needs 3/4 ton pickup, probably
Brand ReputationVery GoodExcellent26RK
Builder SupportGoodExcellent26RK
Likely EquipmentGoodVery Good26RKToilet, shower, etc.
Quality/RuggednessGoodVery Good26RK
Sailing QualitiesGoodVery Good26RK
StiffnessGoodVery Good26RK
Anchor System
EngineOutboardInboardBoth have advantages and disadvantages
Galley
Lifelines/General Safety
Owner NetworkLargeSmall But Keen
Sailing Lines of Sight
Storage Space
Nice list and I'd have to agree with each of your assessments. :thumbup:
Assuming you have the tow vehicle for either then neither boat is clearly better.... ask yourself a different set of questions and then list which boat is better suited. Here is something to get you started
  1. What type of weather are you more likely to sail in? Do you find yourself sailing in lighter air more often (260) or do you sail in areas with blustery breezes (26RK)?
  2. How often a year will you launch and retrieve your boat? Often (260) or only once or twice a season (26RK)
  3. How much time will you spend on (in) your boat at anchor (260) vs. how much time will you spend sailing (26RK)?
  4. Do you mostly day sail where you can pick your weather windows more accurately (260)? Or do you think you will be doing longer trips (passages) where you are more likely to get caught in unexpected storms (26RK)?
Tedd
Jul 25, 2013
779
@rgranger :
Thanks, those are all great questions that will factor into my choice.
For the record, we tow and launch every trip but, because we do, we rarely day sail. When we go it's almost always at least over night, and usually two nights or more. We spend a lot of time at anchor, much more time than we spend sailing. So interior space and comfort are a high priority. My sense is that you're right that the Hunter is a quicker boat to set up and launch. I'm sure the Seaward can be made manageable on that front, with some organization and a few modifications, but the edge goes to the Hunter.
At the moment, we sail mainly on lakes, and winds are light to moderate. But we plan to take longer trips in this boat, in coastal waters. Still fairly sheltered, nothing you could call blue water, but more challenging than what we've dealt with so far. I do want something that's capable for those times when the conditions get challenging, and I feel like the Seaward is probably the better boat, in that respect. But I will plan and execute our trips with due regard to the boat's capabilities, regardless of what boat we end up with. One of the reasons I prefer a trailerable boat is that I can get to great sailing areas without having to sail through some of the challenging passes along the way.
You might want to think about getting a new main for the 260 and have two sets of reef points added. That would get you into the 20 kts wind range and sheltered coastal cruising would still be a good choice.
Likes: jwilcoxon78
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
Builder support: I believe both Hunter (Hunter-Marlow) and MacGregor are out of business; how did you come up with good and excellent, respectively, for these?
Also brand reputation: I know this is a sensitive topic, especially in the Hunter Owners forum, but I would be curious about the spectrum of brands considered? I mean, on a scale of Chrysler to Hinkley, or something like that? From my fairly ignorant perspective I would rate Hunter over MacGregor for brand reputation. But, I would be careful in any event, as I've seen some examples of poor building practices on Hunters in this forum. Here's one that recently came up for the Hunter 260:
H260 Service Upgrade
-na -NA Anywhere USA
SBO HAS ALOT of support and currently owned by a former Hunter employee. As to stiffness, you are correct about the 26 RK but not sure but weighs more which is not good for towing. However, Hunter 260 is designed to be strong but flexible with the use of a foam sandwich core in it; thus the boat is lighter for towing. It has a dedicated mast raise system that works which I know the designer. It sails in a sense flatter but faster. Equipment used is good. I could go on but wanted you to know some facts. Most of the hunters built were designed using principles and experience from boats built and raced solo by the owner of Hunter.
As far as both boats, I would recommend both.
Dave Condon
Former dealer (American Marine & Sail Supply)
walt
Jun 1, 2007
3,541
My experience has been that builder support matters with the motor but for the rest of the sailboat.. much less important.
The Mac 26S is still the perfect boat for me but I like the two choices you are thinking about.. Here are a couple more things that would be important to me..
What is the sleeping arrangement. Do you have to crawl over someone to get up in middle of the night. If you are in a high lightning area, will you be sleeping with long ungrounded lightning rod somewhat over you head?
Zebra mussel inspections when traveling. Crossing into California is easy.. but crossing into Idaho or Utah can be a hassle especially if the inspector is having a bad day and somehow knows about water ballast. Even without the water ballast, sometimes the inspections can be a hassle but water ballast complicates this.
Are you the type that tends to ground underwater stuff on the boat (I do every year even on a lake I am familiar with) or sail in an area where you are likely to ground. The swing centerboard water ballast boat is about as tolerant as you can get for grounding and I assume the Hunter 260 would be better here.
Your "problem" sounds like a lot of fun!
Tedd
Jul 25, 2013
779
@jviss :
I'm going to assume that it was a typo when you said Macgregor, and you meant Seaward, since we're not discussing Macgregors, here.
Marlow-Hunter appears to be still in business, and they list the Hunter 260 as one of their Previous Models, so I'm going to assume it's the correct company.
Seaward has an excellent reputation for customer support. They're now being built and supported by Island Packet Yachts, but IPY is also now owned by Hake Marine, which was the parent company of Seaward. So it seems reasonable to assume that they've maintained their standards of customer support. But I don't have any testimonials to support that. I'm interested in what you may have heard.
Tedd
Jul 25, 2013
779
@walt :
Our current boat is a Macgregor 26S. It's really great value, and you can't top it for being easy to tow and set up, for a 26 foot boat. But I know my wife isn't going to be happy, long term, without standing head room and some other amenities that the Macgregor doesn't offer.
We're in the Pacific northwest (or Pacific southwest, as I like to call it, since we're in southern BC), so lightning's not a big issue. But with the Mac, on those rare occasions when it's a risk, I lower the mast. I have my mast-raising system set up so I can do it on the water, and the mast comes down in a minute or two. Since we tow and launch a lot, I intend to set up our next boat the same way.
We don't expect to ever sail anywhere other than British Columbia, so jurisdictional issues aren't a problem. Grounding's not a big issue here, either, for the most part. Finding shallow enough water to anchor in can be a challenge, though, and, partly for that reason, I never sail anywhere without a chart. But I admit that do like the swing keel, even so, and wanted the 26S Macgregor instead of the 26D, for that reason.
Yes, I'm very happy to have this "problem!" We bought the Mac with the idea that we'd see how much we would like sailing and aim for something bigger, if we did. (And when I say "how much 'we' would like sailing" I mean "how much 'my wife' would like sailing, since I already knew what I wanted.) We're still considering non-trailerable boats because we want to do some serious cruising. But moorage cost around here is a pretty strong disincentive. The annual cost for a 30-foot slip is close to what we paid for our Macgregor!
Likes: walt
SBO IS STAFFED AND OWNED BY FORMER HUNTER EMPLOYEES. THEN THERE ARE OWNERS WHO OWN HUNTER S THAT MANY SHARE THEIR WEALTH OF INFORMATION. Then there is me as a former dealer who has a vast wealth of information to share. Support here is pretty darn good. FORGOT THE OTHER EXPERERIENCED SBO SAILORS WHOM NEET TO BE PRAISED AS WELL AS THEIR KNOWLEDGE IS VERY VALUABLE
Tedd
Jul 25, 2013
779
Thanks, @Crazy Dave Condon . Those are exactly the sorts of reasons that I rated the Hunter as excellent in the "Aftermarket Support" category. It seems to me that, except in very special circumstances, aftermarket support is much more important than support from the original builder of the boat. Loads of people are having satisfactory owner experiences with boats built by companies that have long since vanished from the scene.
Nov 8, 2007
1,590
For me, brand reputation is the least important factor on the list. As a group, we know these boats. We know how they were built, and how they sail. We spend most of our time on this site talking about how to maintain them. So we maintain a "boat reputation" not a builder reputation. The quality of support this site gives to Hunters is a lynchpin of that idea.
If we were talking about a new boat design, with which we have no such experience, then builder/designer reputation would be critical.
I am impressed with Catalina's long term support of their line of boats. But I see that this site achieves at least the same level of support for Hunter boats.
Tedd
Jul 25, 2013
779
@David in Sandusky :
Yeah, I think we're really talking about the same thing. I don't own a Hunter, nor have I been involved in the sailboat market for very long. So, in that sense, all the boats are "new boat designs," to me. Brand reputation, to me, means exactly what you said: A bunch of owners who know the boats--how they were built, how they sail--and who also have experience with other boats, will vouch for them. Not what millions of know-nothings on the internet think, but what people who actually know this particular brand think. (As a Macgregor owner, the distinction between those two things is stark, for me!)
A lot of support here with Catalina too besides the other groups.
I was close to Frank Butler who asked me about new or redesigning boats as a dealer. I understood that I was the only one whom he reached out to for smaller boats plus I stood up to him when I felt he wrong. He respected me for that. However the Crazy part of me came out after a boring dealer meeting in Annapolis one year. He opened up the meeting for comments. I stood up and walked over to him and started singing the Cat Meow song ending with a purr
Frank said he knew I was crazy but now he knew I was absolutely “Nuts.” The whole room laughed so hard and the meeting immediately adjourned for the dinner party which was now in a good mood. Mission accomplished with a thank you from most including my staff
Tedd
Jul 25, 2013
779
Great story, @Crazy Dave Condon ! I had seen your moniker here and wondered where the crazy part came from. Your story reminds me of a couple of the guys in my vintage car racing club, who like to sing a song about German sports cars called "Mit ze motor in ze back" (sung to the tune of The Happy Wanderer).
I like the Catalina 250 a lot, and it was high on my list before I bought the Mac 26S. But standing head room is a non-negotiable requirement for our next boat, so I'm not considering it.
Ye. (As a Macgregor owner, the distinction between those two things is stark, for me!)
I've owned and sailed two Macgregor V21 and a Macgregor V22-2.
Loved all three boats and did some decent coastal cruising in the 22. I would often go hours without seeing land on the V22.
bmorr
Apr 5, 2009
81
Hunter 26 Pueblo Lake CO
WE went from a Mac 26c to a h26 (water ballast) about 10 years ago. We love the interior and cockpit of the Hunter (sails great also). It does take longer to set up, but I only do it 2 times a year so my system may not be the most efficient. Be sure and check the beam, over 9 feet requires a permit in many states.
