Brian, my 05 Honda came with tiller controls. When I bought my 260 it had wheel steering with pedestal controls and cables connected to a Nissan OB. I wanted to keep my Honda motor from my old boat. My Honda dealer told me I could not convert the tiller motor to remote controls. I looked at the parts diagrams for both models on the internet and ordered $135 worth of bolts, clips, springs, levers. I was able to easily convert the motor to remote control and the cables that had been used on the Nissan motor fit perfect. I don't know what the issues would be trying to use say a Nissan remote with a Honda engine. Also I had to make up a small electrical cable to mount the stop and start bottons that used to be on the tiller handle onto the sail boat itself.Another vote for a Honda 9.9 on an H26. I do not have electric tilt or remote throttle and shift... but wish I did! I could be wrong, but I think aftermarket remote throttle and shift are a problem (impossible?) on a Honda 9.9. Could someone confirm? BrianW
I have to ask whether you have a 26 or a 26.5? You've received lots of input from Hunter 260 owners, but if your boat was made in 1987 it wouldn't be a 260 - more likely it's a 26.5 - and the answers for adapting throttle and shift cables could well be different.I have a 1987 Hunter 26 with a Nissan 9.9 2-cycle outboard motor. I'd like to buy a new 4-cycle outboard motor and minimize the changes for the external throttle and shift cables. Any suggestions?
I had Honda dealer add remote control to 1991 10 hp outboard that I bought new without remote control. Was added a year later & still works great (for the new owner of the boat which I sold to buy my 2002 Hunter 270) . They sold me a surplus shifter from a 50 hp motor to keep costs down but still cost about $1,000 for shifter, a kit & labor. A friend (Bob Hussey) added remote control to his newer model Honda 10 hp on his Hunter 260, after being told it could not be done. He figured it out from the manual etc & did it at relatively low cost. Also, on my Hunter 270 with a 9.8 Tohatsu with remote control I copied another Hunter owner & put the shifter in the middle of the stern rail, up high where it is easy to reach & bought a longer, premium cable to facilitate such.Another vote for a Honda 9.9 on an H26. I do not have electric tilt or remote throttle and shift... but wish I did! I could be wrong, but I think aftermarket remote throttle and shift are a problem (impossible?) on a Honda 9.9. Could someone confirm? BrianW
Hi Mike, I'm looking at a 2004 8hp Yamaha motor tonight so yes, you can vote twice!Im from fl so can I vote twice?
Hi Capn John, Yes, you are correct. It is a 26.5. I think the throttle and shift cables are pretty standard but that is a good point. I bought my Hunter 26.5 new in 1988 and it was the boat they had in the showroom.I have to ask whether you have a 26 or a 26.5? You've received lots of input from Hunter 260 owners, but if your boat was made in 1987 it wouldn't be a 260 - more likely it's a 26.5 - and the answers for adapting throttle and shift cables could well be different.
