Hunter 240 Furler
sspan
Oct 9, 2020
10
Hunter 240 New Smyrna
You have a B& R mast rig with no back stay with a larger main that gives you an equivalent of a 135-140 genoa. The lines on deck woould also interfer with the swept back shrouds. The key is to heel no more than 12-14 degrees with sail control. So the 110 jib is max as that is the way it was designned. If you want a larger sail for light air I suggest an a symmetrical standard spinnaker.
Dave have you heard of any issues w the CDI setup stressing the forestay leading to work hardening and possible failure ?? I am moving out with the FF2 and was cautioned this week that was a concern to consider... apparently at the end connection.
-na -NA Anywhere USA
In my years using CDI FF2 if not set up or maintained properly, no issues. However the internal jib halyard line after a period of years needed replaceing. Tuning is important and if loose, can cause an issue but after a period of years, standing rigging needs to be replaced due to stretch and if you see any loose strands, stop sailing and replace that specific wire rigging
Likes: sspan
sspan
Oct 9, 2020
10
thanks Dave. That is what expected based on number of CDIs on Hunters. I get mine next week. I will watch the forestay regardless.
