Hi All -
New to the forum! My boat is a Hunter 23 1986. I've already repainted the full deck as well as replaced all the deck teak - we are loving the boat so there are
a couple upgrades I want to do and all help is super appreciated :
1 - I'm looking to replace the current jib winches on my H23 and would like to put on 2 #6 Harkens. Will the Harkens fit? And should I buy need any hardware or do the Harkens come with all needed to attach to the boat? The current Winches work fine but look extremely weathered. Also they bolt directly into the boat with a wood backing plate inside the cabin.
2 - I'm also looking to upgrade the jib sheet pulleys. Either just by buying new plastic interior wheels (if I can find them) or replacing the whole assembly.
3 - Next I am debating tearing all of the 1980's brown carpet off the interior cabin and
simply sanding off the glue and painting bright white topside paint to the interior - anyone out there who has done this? Is it a good solution rather then re-carpeting?
Thank you!
Thank you!
