When the mast is stepped and in its normal working/use position, is the bottom of the mast supposed to be resting on the base of the bracket, or is supposed to be elevated as in diagram 1?
Basically asking is diagram 1 or 2 correct?
Seems like when I took ownership of the boat it was diagram 1, but I have zero confidence in the previous owner's modifications.
I can see where diagram 1 would make it easier to step and lower the mast as it creates a free pivot point where diagram 2 would not.
Seems like a lot of weight on a bolt if diagram 1 is correct.
Thanks!
Thanks!
