Hello, I'm trying to figure out how to set the Jib on my Hunter 23. It just doesn't seem right to me. When I attach the tack down low to a small cable that just comes out of the top of the deck, and then run the sheets to blocks that attach at the base of a stanchion, the jib hits the lifeline. I'll attach a picture - with apologies, it is not the best picture. I'm wondering if (1) the jib is the wrong size, or (2) the block is the wrong place or (3) the sheets should run outside of the lifeline, which I tried, and seemed worse or (4) the tack should go up higher to clear the lifeline? I tried this last one too, and it still looked odd, there was room to raise it about 18 inches, but then the jib head would hit the top. Also, does anyone recommend a marina in Southwest Virginia that knows how to work on this type of sailboat? I need some work done (windows replaced, stays fixed, motor mount replaced ). Thank you in advance for any advice. Chuck in Virginia with Hakuna Matata on Claytor Lake.
