Fellow Sailors, I am happy with my recent purchase of a H23.5. However I have found that the both the Main and Jib halyards do not stay in the clam cleats. I have seen rope clutches on some boats and I am thinking of adding a triple rope clutch to handle both halyards and the keel line. I will install the rope clutch with a backing plate. The Jib Sheet is also a mystery to me. You can see in the photos, there is a cam cleat forward of the winch. Is it there in case you don't plan to use the winch? Or, is it run as in the second photo. Thanks.
