Hunter 22 Sink Proof?
Aug 1, 2019
51
hunter 22 Colorado
I just bought a 2013 Hunter 22. Has the open transom.
Is this boat "supposed" to be sink-proof?
Sep 22, 2018
1,869
Hunter 216 Kingston
Well I’m not sure any boat is truly “sink-proof” but this is what Hunter published for the 216
https://www.marlow-hunter.com/wp-content/export/Brochures/216.pdf
It states 1500 lbs of positive flotation.
The H22-2 is basically the same boat but has an outer skin of FRP instead of Luran and as a result somewhat heavier but likely almost as “floaty”.
Worst case - the boat broke in pieces the sections would still float.
Pretty safe boat as it self bails and has positive flotation.
Likes: curt in CO
-na -NA Anywhere USA
Your boat has foam flotation within the hull which is stated in the owners manual under boat inf/Hunter resources/22/downloads. As for the open transom in following seas, the waves raise the back end of the boat without any water coming into the cockpit.
Use to be a dealer
Likes: curt in CO
