So I'm working on the deck of A Hunter 170 and there was a need to remove the metal Mast Tabernacle. The screws were very loose, so much so that I was able to remove the screws with just my fingers. The wet wood smell hit me right away. There was trouble down below.
The repair is going to look a lot like the repair @JimInPB made. That can be found in the hunter mod section. I used a very similar process for my engine mount repair.
Ive got a 2004 model so at that time plywood was used everywhere there was a screw. I have yet to find plywood on my boat that is not wet or delaminating. I can actually look at an area now and without making any cuts know if the wood is rotten. Look for hairline cracks radiating from a screw. If you see that, its time to open up the luran.
The worst thing we can do is inject anything in the holes and rebed the threads. That will actually make the cracks spread faster as the new filler will transmit the stress of the screw directly to the luran.
Heres what we start with. The tabernacle, screws, and 2 soft strips.
