Mike
I have a 30 year old C22, that is a sweet sailing boat. The deck, windows, hatch boards, etc are all water tight. The gudgeons for the rudder pintels are not leaking either. I have no thru hulls, except the cockpit drain and keel cable hose, and they do not leak.The keel lockdown bolt has been removed and glassed over. The boat can sit thru a thunderstorm and remains dry inside. I find water in the bilge when I return from a sail. It only seems to appear after a sail on heavier weathered days, where I heel over to more extremes. I suspect that the hull to deck joint is leaking, and will use a hose on it the first chance I get. I can live with this problem for the season and will fix it later. Has anyone ever repaired a problem like this, and do you have any advice.
