Hull Thickness
CaryG
May 23, 2021
4
Hunter Passage 42 Port Charlotte
Looking to install an Airmar P79 on a 1993 Passage 42, does anyone know the hull thickness? Airmar says this works best with 1/2" hull thickness or less. If thicker they recommend the M260.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Welcome to the forum!!
Do you have existing Airmar or other transducer on your boat for depth and speed? If so, you may be able to obtain its model number and check the size. I did that on my sailboat when I purchased a new speed transducer.
JamesG161
Feb 14, 2014
8,005
Hunter 430 Waveland, MS
You should get the M260 since the hull thickness may vary in spots...
My H430 is about 1/2 inch
Jim...
PS: Mine works fine, but Raymarine.
Likes: CaryG
I think the OP is talking about a "Shoot thru the hull" meter instead of the thru hull sensor. But I'm not sure.
Likes: CaryG
CaryG
May 23, 2021
4
Correct! Need to move the boat asap and don't have time to haul out, surveyor recommended this. I'll change the thru hull next time I haul for sure.
CaryG
May 23, 2021
4
Not sure but we've got to move the boat asap and don't have the time to haul out. Thanks
Feb 21, 2013
4,638
You do not need a haul out to check the transducer. You can remove it (built in check valve ro minimize water entry) and insert its companion plug. Then you check the model and look up its hull thickness dimensions.
  • Helpful
Likes: ggrizzard
CaryG
May 23, 2021
4
thanks!
JamesG161
Feb 14, 2014
8,005
If you can not find that Plug...
You can remove the thru-hull transducer, have a helper hold hand over the slight flow, you clean the transducer, take picture of the Model, and re-install it.
Maybe a quart of water enters you boat.;)
Jim...
  • Helpful
Likes: ggrizzard
