Boats Don’t Read Current Tables
I can leave the current tables on board, opened to the appropriate page, and still my boat won’t pay any attention. It’s only concerned about how fast water molecules flow past it’s hull. Boat speed. Period. Sean, would you trim your boat any differently depending which direction the current flows? Is your recommendation for performance improvement is to move to the Admiralty Inlet? SOG is pretty meaningless in this type of discussion because current has no impact on how well the boat is performing in relationship to the surrounding water. Sure, it’s a lot more fun sailing with the current than against it, but current alone, has no impact on how you trim the sails.*boxAllen, how far in the harbor are you? We may have the same problem in Alameda, Ca., we are about three miles down a narrow (no wider than 100 yds) ship channel. We usually bite the bullet and motor out – no fun doing 40-50 tacks in a very crowded channel. At 10kts WS, my C34 is somewhere in the mid-upper fours. In 15kts and “flat” water I can hit hull speed. However, my boat is “tricked out” somewhat, and your experience seems reasonable to me.If I can be critical about Catalina’s is that they tend to be on the heavy side and their performance in light conditions can be a bit lack luster. If you want sport boat performance, you need to buy a sport boat. But if it’s any consolation, those sport boat boys are living out of Coleman coolers, water jugs and no headroom.Remember this rule: “Speed costs, How fast can you afford to go?” How much are you willing to spend to get that last (consistent) half knot, $5k, $10k? There are a couple of things we did “on the cheap” to improve performance. We did a weights and measures thing this past summer and it’s surprising how easy it was to find a couple hundred pounds of superfluous gear. If it doesn’t make the boat go faster, leave it at home. Don’t keep your water tanks topped off. Water is truly dead weight. Bring only the amount of water you need for the trip. How well are you trimmed fore and aft? The newer, step through “sugar scoop” sterns are much more sensitive to fore and aft trim than the older, “IOR” style sterns. Are you dragging stern? Take weight out of the lazerettes if you are not getting a smooth bubble stream off your stern (hearing gurgling is definitely a bad sign). If that doesn’t work, move crew to the leeward and forward. Try aligning your two bladed prop with the strut (Paint a mark on the shaft). While not as good as a folding prop, you will cut your drag significantly, and without spending a couple grand. Are you a sail trim tweaker? We find that we need to be very aggressive trimmers on light air days (drives my wife nuts!). So you got $5-10k burning a hole in your pocket? First, buy a folding two blade prop. Sure, prop walk will be a major hassle, and you probably will loose some top end motoring speed, but you’ll be kissing your bucket dragging days goodbye. Fair your bottom. Get rid of that ablative paint and replace it with the hard racing stuff. Wet sand a least the forward sections to get rid of the brush strokes. Take comfort that you will be putting your diver’s kids through college, but at least you’ll be the fastest C30 in the marina. How well do you point? Do you need Cunningham to pull the main’s draft forward? If so, time for a new main. I’d consider replacing it with one that is free footed or has a shelf. Full battens tend to flatten the sail while partial battens will allow you to trim for more belly a lot more efficiently. Go to adjustable fair lead cars – it makes tweaking the jib a lot easier. Speaking of trim, has your rigger checked the rig lately? How is your mast rake? Are you getting slight weather helm (5 degree rudder angle at low speeds?) If not, try moving crew to leeward to induce a little helm. One pound aloft is equal to 5-10 pounds on deck. Have you considered replacing halyards and topping lifts with smaller diameter (and lighter weight) Spectra or Technora? Less weight aloft will make you a lot more responsive to slight changes in wind. As you can see, one can go to the poorhouse trying to get that last half knot. To put things in perspective, I occasionally sail on a boat that is quite capable of doing 6 kts in 10kts of wind. However, it only costs about a third mil, has a reacher larger than my old apartment…
