Hull Paint Question
Ryan Ericson
I am getting ready to use poly glow on the hull of my C30. I have noticed blue flec in the white paint. Is this the primer showing through? I have not tried to sand it in cases the gel coat has worn way. Any suggestion would be helpful
P
Paul
gel coat
That is your gel coat wearing thin. There is another layer that is blue under your surface gel coat. Sanding it will only make it worse. But if you are going to paint it then the most important thing is a smooth, well prepped surface so sanding is what you need to do. Good Luck!
