Well right, they are my observations. But I actually saw them. Two of the damn things almost hit me. And yes the failures are related to failure of the chainplate support area, but that's kind of my point. ALL these designs are good until they fail. That failure is caused by damage, wear&tear, or material breakdown. When in good condition, rigs don't just fall down. That's true on ANY boat. Thats why the OP needs to sort out his boat.If we're going to compare your anecdotal observations:
Please refer to the pictures I provided of my previous boat. Although difficult to see in the perspective, both the jib and staysail overlapped the mast and the chainplates were bolted to the hull sides. That's a 1970's design.
- Of the failures you quote, how many of them were supporting hull structure failures as opposed to chainplate or rig failures? In this instance the chainplates and rig are still intact, it's the supporting structure that failed.
- Of the failures you quote that were actually supporting structure failures, what were the ages of the boats? If we're comparing apples to apples, age is a factor.
- Of the failures you quote, how many of each model were produced? This figure gives us a failure rate for the design, design being in question right now. For example, there were roughly 7,000 Catalina 30's produced compared to roughly 120 Beneteau 311's. An equivalent failure rate would be 58 Catalina 30's to this one B311 and again, that's supporting structure failures.
Yet he designed the most successful 30 footer in history, naval architect or not. I'd suggest using a different example.
What do you mean up to snuff? What about the Catalina history was not snuff-worthy? I'm not suggesting Gerry Douglas' work is not outstanding, it certainly is but what was in defect before he arrived?
The pix you show are cutters. That's totally different. And for whats its worth, I don't think that they are Catalinas.
I sense you're starting to take this personally and that's not my intent. So I'm going to drop this.
