hull construction
Aug 13, 2014
8
oday 322 whitby
Can anyone tell me if the hull below the waterline is solid fiberglass? If not then what is the composition?
Sep 23, 2009
1,480
I believe that all o'days are solid hulls. Where I have replaced through hulls the thickness has varied from 3/4 to 3/8 inches.
Aug 13, 2014
8
oday 322 whitby
Do you know if they are solid throughout or just below the waterline. I am trying to install a depth sounder that reads thru the hull but the bottom has to be solid fierglass
thanks
Dec 27, 2012
587
Precision Precision 28 St Augustine
I had a 22 footer and currently a 240. They both have a transducer that shoots through the floor. No problems with either.
My 240 has the wing keel. I ended up mounting it in the rear quarter berth storage area.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Solid hulls. Only balsa cored on decks and cabin tops and such.
Nov 3, 2010
564
Oday 39 Lake mills WI
O'day 40 have cored hulls.
I attempted to use a depth sounder that went through the hull on my solid hull 39. It did not work but the sounder company said that it was not unusual for the sounder not to work in large older boats that were designed and built before gas prices (resin) went up. More modern hulls are likely designed better and therefore much thinner.
