Just a couple of quick comments, diesel fuel is really common in Mexico and I would presume throughout Central America, price in town is comparable to most US gas stations. They do get alot from the prices they pay. It builds the roads, schools and hospitals. Most of the larger fishing boats are running on diesel.
There is freqently a surcharge imposed by marina operators of a dollar or two a gallon and restricitions on bringing fuel through the marina from an outside source.
There is an over abundance of smaller fishing boats runnning on gas. These are usually open skiffs around 20 feet long and running on big outboards, usually over 70 hp. Typical crew is 3 and they are working smaller gill nets or fishing with handlines. They need big outboards to move a skiff full of fish. There was a problem with outboard theft when we were in Mexico. 3 to 6 HP motors were okay but when you started getting into the 9.9 to say 25 HP or so problems with them leaving the boat in the middle of the night developed. Big outboard breaks down at sea and the fisherman could die. 9.9 or better will get the skiff home slowly.
We got around the fuel restriction by having a sunbrella bag made that would fit our folding cart. We sized it to carry several loads of grocery bags or a 5 gallon fuel jug. All of this information is dated. We cruised Mexico 10 years ago. Tha vast majority of the folks we ran into were wonderful people. In two season we had one incident in which a pole I'd left out on a rail mount overnight was stolen while at anchor.
Just as an after thought, we were to heavy. Light winds had us motoring way to much and the lower the boat is in the water the more diesel you burn. We carried to much food and to many spares. Most of the spares returned with us. Doing it again I'd carry less tools and spares only for essential equipment. Our abandon ship bag was way over supplied considering the EPIRB would most likely had us rescued in a day or two. Every 30 or 40 pounds you can take off of the boat will improve your sailing. It can also mean making an anchorage during the day instead of being tempted to try and enter at night.
We did that once and Judy kept yelling at me to drop the hook. I kept thinking the deeper we anchor the more chain I have to pull. I relented and dropped in 20 feet. Set the hook and woke up the next morning with a reef about 8 feet off of the stern. It was one of those moments when you know you're busted. There was no way I was going to be able to pull a hundred feet of chain without her waking up. I still hear about it!
Walt, S/V LyricTo:
AlbinVega@yahoogroups.com
Date: Mon, 12 Oct 2009 09:27:29 -0700
Subject: Re: [AlbinVega] Re: How Weight affects Performance
High Kenneth,
I have been doing ours one for the last 3 years (Ocean Sunrise) and just about to be ready to go (6 more months).
So far I have put in most of the non supplies ?essential? chain, windvane, windlass, anchor, galley, liferaft, dingy, sails (6 of them), lines (400 mtrs of 12Cm, ?light? ones), heater, etc.
All of it I recon must come to around 350Kg, however I have taken the inboard out which has given me an extra 120Kg.
The net effect is that I still have about 1 inch left on the water line, the down side is that using the formula provided by Bill, it gives me that I still have another 3 inches more to go down by if I include all of the gear I would like including consumables, however I am after some very out of the way spots
Bob is absolutely right though, I am already running out of space and it will take quite a bit of coercing to be able to fit the rest.
Ref the sailing in Central America, I dare say that outboards are very common (I know that even in the most out off the way places in Venezuela they are) in the area therefore petrol should not be a problem, however diesel might be a different proposition.
On the upside diesel engines consume far less, so it should balance its self out, ref reserve, just fill in were ever you can!
How it affects performance, I went on a cruise 2 years ago and we were loaded with food and water for 15 days with pretty much the same equipment (plus the inboard) as now, she was at the waterline then or a little bit bellow, she felt a bit heavy but handled better at sea once she was properly balanced.
What I did noticed though was that if the bilge is over full (ie splashing over the boards) she behaved kind of ?drunk?; which I put down to the water taking over in every heeling movement.
So as long as everything is tight, she should be fine or at least that is what I hope!
When are you starting your trip?
Cheers
Roger
