I appreciate the response. If you ever get your boat and trailer rigged up like that again, take it out for a sail and let us all know how she does. ; D
K.L.Magee
________________________________
To: AlbinVega@yahoogroups.com
Sent: Wed, December 2, 2009 6:15:39 PM
Subject: Re: [AlbinVega] Re: How Weight affects Performance
I got to test the "each thousand pounds will put the Vega an inch lower in the water" theory this fall. I was putting the boat in the water on a steep ramp and had just disconnected the trailer from the truck to attach a 30' strap to roll the boat and trailer out into the lake, when I heard the plastic wheel chocks behind the trailer wheels start to crack.
When the chocks let go, the trailer and boat took off into the lake. Luckily, the the boat and trailer went out parallel to the floating dock next to the ramp and I was able to grab a line and stop the boat. It was also lucky that I hadn't unstrapped the boat from the 2000 lb plus trailer. The boat became the trailers "flotation device" that suspended the trailer, preventing it from continuing on out a hundred or more feet down the submerged boat ramp.
I did notice that boat was sitting about 2" lower in the water with the trailer hanging off of it. However, I didn't take the boat out for a sail with the trailer attached to it, so I can't really say how the extra weight affects performance. In my case, I feel it is safe to say that it would have sailed a lot worse.
K.L.Magee
