Mark
I am trying to reassemble a single speed Lewmar 8 winch. This does not have any bearings. I am most confused about the white plastic widget used to keep the winch from sliding off - it is like a locking wedge. I know where it goes on the winch inside base, but how do you properly engage it or lock it into the outer hub (the part that actually accepts the lines?It seems to fit completly inside the inside base - which makes it's useless.I hope this is clear, Thanks!!Mark
