How to dry gelcoat - fiberglass? Indoor!
Mar 30, 2014
28
Beneteau First 375 qc
Hi, I did open my rudder to remove wet foam core and before pouring new foam in, I want to make sure that the fiberglass / gelcoat will be perfectly dry. Rudder is indoor at 18-20 celcius for one month and still humid according to grp33; any trick to dry the core?
1,480
Easy sqeezy....drap plastic tarp over it and put a portable dehumidifier in the resulting tent. Will dry out an ocean.
MSter
Apr 12, 2010
131
Sabre 38' MK II Oriental, NC
Try a heat lamp, the boatyard here uses heat lamps aimed at parts of the hull (after gel coat peeled) to dry out wet sections . Seems to work and that is outdoors.
Mike
s/v Ladylike
Mar 30, 2014
28
Heat lamp is a good idea! Do you if an electric heater oriented on the rudder could do the same?
Deshumidifier sounds good too but I dont own one!
