Hi All,
I need some advice. I recently discovered that the pump out station we use "times out" after a certain amount of use. After taking longer than normal to pump out our first holding tank I only ended up pumping out half of the second sanitary tank (the pump timed out and I thought I was done). As a result my normal calculations for head usage were ... well ... a bit off. So we overflowed the forward sanitary through the vent. This resulted in a someone embarressing brown streak on my hull.
First, thanks to some other posts on this site I've found a few good tank level products and will look to install this winter so I can monitor both holding tank levels (and maybe the water tanks as well - They seem to be set to run out during my shower time).
Second, I've tried scrubbing this streak, used kitchen cleaners, non skid cleaners, and elbow grease. I've dulled it but it is still very visible.
Any thoughts on what I can use on this stain to get it off my hull.
Any help would be great!
Glenn
Glenn
