I have a Catalina 30 Mk III with a fully battened main.
I'm haivng trouble getting the main up and tensioned so I chekced the sail slugs and they are badly worn - so I plan to replace them.
The sail has grommets on the luff for attachment of the slugs - but these actually are in pairs. Each pair is about 26" or so apart with the grommets in a pair being about 3 or 4 inches apart.
All of the info I can find on the web about attaching slugs shows them being attached to a single grommet, with a pretty simple loop of webbing, secured by stitching.
Can anyone provide info on how the slugs should be attached to pairs of grommets? The current arrangement seems to put quite a bit oif twist into each slug - so I'm not sure I really want to copy that approach.
Note that the grommet pairs are on either side (above and below) each batten, but they're also there even when there is not batten.
Do I need to use both even for the intermediates?
Any advice will be gratefully received.....
NOTE : I have ordered the Allslip slugs from Bainbridge - they claim to be lower friction and they seem longer than the existinhg ones so I'm hoiping that'll help when I eventually get them onw. Of course, I'll be cleaning and lubing the track too, as per many of the threads on here.
Thanx in advance,
Doug
Thanx in advance,
Doug
