See this article
Kip, have a look at this article that explains the concepts: http://www.boatus.com/goodoldboat/stability.htmThe equation is expressed in an unfamiliar way here, I believe he is saying take the cube root of [maximum beam (in inches) divided by displacement (in pounds)]. Ordinary calculators don't do cube roots, so you may need to borrow or buy a scientific calculator to do it. Your number should always be between 1 and three, usually close to 2.I found in doing calculations for my boat that the weight specifed for the boat in the literature put it over 2, but adding some weight improved the number; after adding about 700 pounds, there was no improvement. That seemed to indicate that the builder had factored in 700 pounds as the expected additional weight of passengers and cargo...
