How much of a drip?
159
Catalina 387 Hampton, VA
Ok so I am looking at the packing gland and wondering if I am getting enough of a drip from there. If the shaft is not moving should there be any drip? I know it should be 2-3 drips a min, but is that all the time? THanks for the insight!
Jun 11, 2004
1,937
Oday 31 Redondo Beach
drip
I like no dripping when the shaft is not turning. A drip or 2 a minute is plenty when running. If you use the GORE teflon packing you can get to way less than that and still be OK. The key is that the shaft / stuffing box do not get hot. If the box is cool to just barely warm to the touch after you have been motoring for a while, you have enough drips.
Consider an archive search
on "packing gland" (exact phrase) Lotsa reading there.
Bill O'Donovan
Drip
Yanmar guy told me it was an old wives tale about the drip. Have you ever seen a shaft of a sailboat scored from overly dry turning? Not any more likely than finding a dead cat in a tree. That's not to say one should overly tigthen the big brass nut, but enough to stop the drip. I could be wrong.
May 7, 2004
75
Catalina 28 Cedar Rapids, Iowa
Drips
Mine doesn't drip sitting at the dock. I ran my motor down the lake last weekend about 10 miles. When I got back to the dock I went down below and felt my packing gland. There wasn't much water under it, maybe a puddle 2 inches around. I felt the gland and I could touch it and it was kinda luke warm. Almost felt like the heat was coming down from the engine. The more I moved up towards the transmission the warmer it got but never more then I could hold on to. Anyone have any idea what is too warm. I have no idea when the packing was last changed in the boat. Jason
G
gr8_2_av8
drip
When I put my first boat in for the first time water came in while just sitting in the water. The cutlass bearing had been changed by the yard so I guess that was to blame. I tightened the nut quite tight and got no dripping. After about 40 hours of motoring I now get a drop or 2 every couple of min.
