How long can I run 15HP outboard continuously?
Aug 10, 2020
544
Catalina C25 3559 Rocky Mount
in good tune, it should run for years under constant use. it's corrosion, poor fuel/dirty carbs, cheap oil and sitting that kills them.
I've seem rental outboards go for a decade plus getting the crap ran out of the daily 8 months a year 10 hours day. it's all about maintenance and the hardest thing on them is sitting.
Lazy1
Aug 23, 2019
183
Ericson 35-3 Erie PA
My outboard just needs occasional pumps of the fuel bulb if it runs for over a hour. Probably something I need to address maintenance wise.
Have you considered that it may imply be the fuel bulb?
Jun 7, 2016
315
Catalina C30 Warwick, RI
Outboards are designed to be run long and hard. Aside from wearables that need regular maintenance anyways, it would be highly unlikely to have an internal rotating part fail from constant use. (unless of course the previous maintenance has been neglected and hasn't had oil changes etc.) other than that I wouldn't be concerned at all.
Do you sometimes forget to open the vent on the fuel tank.
