how is air getting in pressure water system?
gwp
Feb 25, 2004
33
- - Pirate's Cove, AL
Have filled up both tanks past the pickup hoses and still getting air in system. How can this happen? Can't find any water leaks but even if there were it seems to be insufficient pull on water from tank to suck in air. Ideas?? Thx
Dec 25, 2008
1,580
catalina 310 Elk River
From the suction side of the pump?
Not air at all, hydrogen?
RichH
Feb 14, 2005
4,773
Could be that when filling the tanks you 'entrained' a lot of air in the water causing a great amount of micro-air bubbles to become 'mixed' in the water. These bubbles sometimes take a long time to 'effervesce' out of the tank water.
Try filling the tank 'gently' so as not to mix-up a lot of air into the water.
Other possibilities: 1. leaking seal / o-ring on the 'suction side' of the pump. 2. pin hole or loose connection on the 'suction side' of the pump piping. 3. pin hole in the pump diaphragm or developed air leak in the pump gasketing, etc..
Best way to 'test' for the above .... blind off the suction side of the pump/piping, (thumb usually works), turn on pump to develop max. vacuum, shut down the pump and see how long it takes for the vacuum to 'decay'.
Nov 6, 2006
10,254
ususally a suction side fitting.or tank selector valve packing?. air can get in where water can't get out. in addition to previous posts, make sure that the inlet is covered by about 2-3" 'cause air will entrain from the surface down the side of the inlet tube sometimes if the tip is not covered deeply enough.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
These kinds of problems are mostly caused by either a faulty pump, faulty pump connections, or input or output sides of the pump being clogged.
Tim R.
May 27, 2004
3,626
Make sure you have bled all faucets hot and cold. Galley, head, transom, toilet(if equipped with FW flush)
BarryL
May 21, 2004
1,127
Hello,
I had a similar problem last year. In my case, I had removed the strainer before the water pump to clean it. When I re-installed it, I turned it a little too much and cracked the threads. That allowed the pump to suck air. it took a long time to find the problem.
Barry
RichH
Feb 14, 2005
4,773
Simple question: do you have a hot water heater? .... have you 'burped it' to remove the inevitable large 'air lock'/entrapped air when you refilled the system?
Beneteau 323 Annapolis MD
...it seems to be insufficient pull on water from tank to suck in air. Ideas?? Thx
My B323 had a similar, hard-to-find problem. Turned out there is a very small check valve right in the water tank's exit fitting. Had a small spring like a ball point pen, and apparently some junk got in it and prevented the valve from opening. I had almost bought a new water pump until I found the problem. I removed the valve and the system works fine without it.
