How far have you gotten thus far?
Oday 35 and Mariner 2+2 Alexandria, VA
So far...rebuilt fridge, new hoses for the head and pump out, changed the oil, flush antifreeze, oil the teak inside, repacked both jib winches, rebedded block for main sheet, edge dressed the genoa, new jib halyard, new mainsail, led lighting throughout, rebuilt gps mount, installed wiring for the gps down below. Also sanitized the fresh water system and am going to install an accumulator. rebuilt thru-hull and raw water distribution hoses. Just made new sail ties, and replaced a dock line. Washed main halyard, jib sheets and main sheet. Oh...and went sailing on sunday!
Oct 10, 2009
1,100
Catalina 27 3657 Lake Monroe
Rebuilt galley sink, freshwater tank, drain and supply lines
Replaced centerboard wedges and pin
Cleaned and bottom painted CB trunk
Repaired CB gouges
Replaced CB pendent
Installed topping lift block
Touched up bottom paint
Waxed hull
Cleaned topsides
Ready to Splash!
Lot's of stuff can be done at the dock, but getting her in the water means I can sail when the weather is nice!
caguy
Sep 22, 2006
4,004
Ok, you asked for it.
Removed 15 gallons of gas and water from floor and bilge.
Scrubbed floor and flushed out under floor. (No more stinky gas smell.)
Repainted bottom
Added bunk to trailer to support keel.
Added guides to trailer.
Added retractable 13' extension to trailer.
Rewired mast.
Replaced mainsail.
Replaced steam/deck light.
Converted anchor light to LED.
Installed antenna on mast-head.
Pulled G-8 antenna wire.
Installed new VHS radio.
Install new stereo and speakers.
Installed GPS.
Installed alarm speaker.
Installed bilge pump.
Installed Fresh water pump.
Replaced fresh water plumbing.
Repaired alcohol stove.
Installed 465 Thetford head including pump out and vent through holes.
Moved fresh water inlet forward away from pump out.
Placed bent shroud shackles.
Replaced hinged mast base.
Installed through deck electrical connector.
Rewired and replace fuse/switch panel.
Replaced interior lights with LEDs.
Installed 2 new batteries.
Removed on-board motor and replaced with 1/2'' aluminum plate.
Installed motor heavy duty motor mount.
Adapted 15hp outboard to inboard controls.
Replaced gas tank.
Removed, sanded and Cetoled all exterior wood except combing trim.
Made new teak eye brows and slider wood.
Cleaned and re-oiled interior wood.
Sanded and Varnished tiller handle.
Repaired damaged rudder tip.
Removed all molded curtains.
Rebedded one window.
Installed new carpet.
Made new interior and cockpit cushions.
Made tiller and winch covers and rope and winch/drink holders.
Made new Sunbrella mainsail cover.
Installed new Winchers. (expensive for what you get but worth the convenience.
Repaired foils to furler,
Replace furler line and added jam cleat.
Repaired tears in furler.
Replaced missing battens.
Added a topping lift.
Replaced dock lines with 1/2'' x 20'.
Replaced anchor line and chain after scrubbing out anchor locker.
Made bridles for temporary stays when raising mast.
Raised mast.
Things to be done during sailing season.
Finish removing and rebedding windows.
Clean and polish deck and freeboard.
Install tiller pilot.
Install tiller extension with lock box.
Make stern rail perch seats.
Make new combing trim and refinish the other.
Finish sewing head sail repairs.
Install fishing rod holders on rail and interior.
Install transducer for sounder on Garmin.
Install windex and antenna whip that I forgot to put in before raising mast. :doh:
Buy more Malibu rum.
Things that can wait until winter.
Recover safety wires with new plastic.
Strip and varnish companion steps.
Repaint trailer.
Sand and paint freeboard (repair small blisters).
Repair cracks and paint deck including non-skid.
Install drawers under seat and v-berth.
Make slide out to extend starboard bench seat for sleeping.
Install Lazy Jacks.
Maybe rebuild or replace inboard motor.
Install an anchor roller.
Given condition of my old back a windlass is starting to look good.
Get back to Luger 30 project.
Where does all the time go?
caguy
Sep 22, 2006
4,004
I've gone a long long ways, backwards.
Much of the interior joinerwork is torn out.
The entire holding tank system and piping has been removed.
The chainplates have been removed
The standing rigging is all scrapped.
One of the mast spreader mounts is off the mast and the other will be soon.
The exhaust hose is removed.
The propeller is off.
Who knows where it will end at this rate?
A pile of parts? ;)
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
I read some books about what I should be doing. Does that count?
Ray
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
re: hydrocoat
So far we've reuphostered the interior and prepared to repaint. I took a pressure washer to the hull and blew about 90% of the old bottom paint off. I'll scrape the Klingons later, then sand it smooth. I decided on Hydrocoat for a few reasons. Seems like a good product.
I have been using it for the past six years in Boston. The water cleanup and low VOC are nice. The only thing I could even say is an issue is that it seems to build up quickly so I took to using it (it is multi-season paint) for two seasons, with just a recoat of the water line and leading edges the second year. That has helped quite a bit.
BobM
Jun 10, 2004
3,269
Spring? What is that?
We got six inches of snow last week at home while we were touring Italy last week. I did finally get out to the boat to check on it a few weeks ago and she survived the winter and its 4+ feet of snow fine.
The only progress I made is that I finally talked my Wife into helping me make a sunbrella companionway cover. We discussed the project and ordered the thread and hardware from Sailrite. It came in while we were gone. She asked about fabric, and I told her that I already had about 15 yards of pacific blue sunbrella hidden in her sewing room :dance:
I need to get off my butt and get my new freshwater tank ordered so I can get it replaced soon. The first day back from vacation my Wife told me that she wanted to make a list of things we needed to do and that she would need my "help" with some of them. Hmmmm....sounds like a faintly disguised "honey-do" list as her typical modus operandi is that I get to do 50% of whatever "she" has to do along with 100% of my stuff (yard work...car repair and restoration...boat maintenance...etc...).
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
So far...I've reserved my launch slot for the morning of May 9th. That's about it. The only thing I really want to do before launch is clean and wax the topsides. Everything else can be done in the water where it's a lot easier than climbing the ladder with an armload of parts.
I will be installing a brand spankin' new head and holding tank system, oil pressure sensor, and new alternator bracket.
More small "mess about" projects but nothing major.
Nov 16, 2010
81
Catalina 22 Mactaquac Headpond
Still waiting for the snow to melt and the ice to go. I have ordered some parts though.
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Headed down in the morning to:
Mount dodger hardware--- finally
Put boom back on and rig (2 boats)
And Monday:
Graphics
Get engine ready
And that gives me a week to finish anything that doesn't get done before the 20th.
Mar 8, 2011
296
Ranger 33 Norfolk
HA! List or Wish List?
So far:
Bottom painted
Keel trailing edge faired and glassed
Rudder shimmed (gotta love Chinese Food lids)
Cleaned old name off
Cleaned a lot of yellow staining off
New prop shaft
New stuffing box hose and packing
Zincs
Mast pulled
Boat refloated
To do:
New rigging
All rope main halyard
Mast wiring
Anchor light
Steaming light
Check chain plates
Re-step mast
I think that is the bare minimum to get back to sailing safely till the middle of summer. To danged hot for me out on the water, but I can close the hatches and turn on the portable AC and get some work done inside :D Then enjoy some fall sailing, then more work with the heater going over winter lol. . .or maybe move in :dance:
I wanted to paint the topsides over the summer, but am debating a second haul out. . .also not going to have the 155 Genny recovered right now, $500-$600 quote back burned that :snooty: I have a near brand new 135 I'm going to run up the furler and use for now, lol. . .
May 23, 2004
3,319
It is time to de-winterize and canvas my boat! Next weekend I may even leave the slip. I can't wait!
zeehag
Mar 26, 2009
3,198
ROFL!!!!!
ENSENADA!!!!!
next stop---mazatlan....
how bout you guys???? how far ye REALLLY get????
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Wow we are a bunch of motivated nuts, actually I have gotten to the point where I enjoy working on the boat I don,t keep track any more. I go every weekend rain or shine. Very soon it won't have to be weekends, I ,ll be there all the time. Its hard to put in words however, I can't imagine life without it....ladies and gentelmen raise your sails........Red
