UPDATE: Talked with Hunter 1 to 1 this afternoon. They’re pretty busy with calls currently - shocker
. Talked with Al, apparently the owner of SBO. Very helpful. Knew exactly what I needed to do, gave me three ways to do it, and if I chose to do a non-destructive thru bolt he offered to send me plugs for the plastic headliner that I could put in 1” holes to look nice and neat.
What I learned:
Method 1 - Drill and tap clutch screws into the glassed-in aluminum deck plate as Jeff356 laid out. Only difference was he didn’t recommend butyl, but Dow 795 White sealant, which is what the factory used. There’s no core in that area
Method 2 - Since a clutch is a fitting which sees stress, like a cleat, he said the factory would normally thru bolt it. However, there’s no getting the plastic cladding off the ceiling of the sink room easily or non-destructively due to the way the boat is manufactured. Instead, try to best determine where the screws are in the overhead and if they’re not in a rounded area, do the following: Drill and tap the aluminum plate, and then drill a SMALL pilot hole with a long bit all the way thru the cabin top and shower overhead to ensure the intrusion is in a flat spot. If not, stop, and install clutch into aluminum plate and plug the small hole. If in a flat spot, drill 1” holes around the small holes in the sink room ceiling penetrations, use those neat 1” holes to thru bolt the clutch, then use the push-in plugs Al has to neatly cover the 1” ceiling holes.
Last resort: Tear it up if you can’t drill thru flat spots and feel you MUST thru bolt, and Al can talk someone thru restoring a ceiling. Which sounds expensive. And you’d want to talk to Al before destroying anything.
I’m trying the least destructive way first. Thanks for breaking that ground and sharing Jeff356. And thanks to Al for talking me thru it. I’d definitely use their Hunter 1 to 1 service again.
UPDATE:
Successfully drilled, tapped and bolted the clutch to the port side without thru bolting. The plate seems pretty substantial, and for a light air spinnaker I feel certain it'll be plenty strong. I did use butyl, since I couldn't find Dow 795 White.
One note though, I'm still going to have to cut and resplice my endless main furling line so I can move it to the two most inboard clutches, since the spinnaker halyard will have to go on the outboard port clutch, due to the relative positions of the furling line and jib halyard. Both of those lines will have to be inboard of the spinnaker halyard.
It seems the factory almost centered the triple clutch, which really doesn't do an owner any favors if you want to add a clutch. It would've made more sense for the factory to mount the triple clutch as inboard as possible, leaving an outboard position for the spinnaker halyard clutch, but there wasn't enough room to do so, so I had to mount it inboard of the triple clutch.
