How best to clean dirt and stain from textured deck surfaces
Apr 5, 2009
3,131
... pre-spray the soiled areas with simple green, awsome, purple power, or any other strong cleaner of your choice and spray away with the pressure washer...
I word of caution. Simple Green is very harmful to any acrylic surfaces. If you read the fine print on the bottle it says not to use it on acrylic because it will cause crazing of the surface. I didn't read that before I started using it and found out the hard way.
When I got my boat all of the ports were perfectly clear but after one season when I used SG to clean the deck, they were all covered with tiny spider cracks and now I can hardly see out of them. :cussing: I have replaced the lenses in the opening ports and plan to replace the fixed ports as well.
Very expensive lesson. I do not know about the others but I now read the label of any cleaning product very carefully. :doh:
I agree that it does a great job of cleaning the non-skid decks so if your ports are already trashed then it is a great product.
May 31, 2014
7
Macgregor 26x Georgetown ME
Re: How best to clean dirt and stain from textured deck surf
Sailing is over here in Northern Michigan. So the boat is in the barn and I have time for a thorough cleaning. The smooth parts of the fiberglass are responding well to rubbing compound and elbow grease, but how to get the dirt out of the textured non-slip areas? Power wash? Stiff bristle brush? Bleach?
I know I'm a retired dentist, but PLEASE don't make me do the whole thing with a toothbrush.
I'm a retired dentist too. Stiff scrub brush and any boat soap. Works really well in the backyard on the trailer when you have plenty of rinse water. I think this is quicker than the power washer.
Dreamcatcher
May 10, 2013
9
Catalina 2001 400 MKII Charleston SC
Best thing that I've had success with is Mr. Clean Magic pads. A little rubbing and comes right off.
Mar 26, 2014
1
Oday 272 Fern Ridge Lake
For a comparison of 13 products for marine use, the January 2009 issue of Practical Sailor does an excellent job. See the link below.
http://www.practical-sailor.com/iss...Boat-Soaps-for-Regular-Washdowns_10953-1.html
Feb 11, 2008
3
Hunter 31_83-87 Dartmouth, NS
Black skid marks
I use Scrubbing Bubbles. Spray it on, leave it for about 10 minutes, then wash it off. Be careful not to get it on your clothing.
Aug 16, 2006
281
Ericson 32 Oregon coast
Hard to beat a good stiff brush. Going over it with
bleach afterward will help with any organic stains. Let bleach sit on it for a few minutes then rinse. "Grease Lightning" is good for oily/greasy stains.
Db421
Jun 7, 2004
95
Hunter 34 1986 Lake Lanier, GA
KaBoom with a stiff bristle brush. Scrub it in lightly, let it set for a few minutes, then scrub & rinse. I try to stay away from marine products unless there is a definite benefit($$$).
Oct 6, 2007
2
- - Toronto
I have had great success with power washing without any cleaning agent. Its non toxic, environmentally friendly and zero cost (except for water/electricity if you pay for it)
You can also power wash your lines and you will be amazed at how clean they are afterwards. Makes them look like new.
Gunni
Mar 16, 2010
5,937
+1 for the Starbrite Super Orange that Practical Sailor endorsed. I find that if you wet the deck, apply a soap solution and keep it damp for a few minutes of brush scrubbing and rinse it off that it does the best job of any boat soap I have used. It seems to be extra effective in the sun. Gelcoat is like enamel doc, thin and porous. Don't get too crazy with the chemicals or abrasion.
Nov 17, 2009
20
Catalina C-310 Falmouth
Mr. CLean Magic Erasers will do the trick...they are amazing!
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Don't try this!
On my Siren 17 that I dragged out from under pine trees ware it had sat for 7 years and had raccoons living in it, I used a 2000psi power washer. That wasn't good enough. So I purchased a hull and deck cleaner (Can't remember what brand. See pictures.) and used it. Still stained...
So I went to the hardware store and got liquid drain cleaner. (ACID! Two types if I recall properly.)
(First I put on goggles, rubber gloves and an organic vapor respirator then \ put the drain cleaner in my garden sprayer and sprayed the deck and hull.) Don't do this on the lawn! Don't do this with cars parked near either.
(\ then took my soft car wash brush and gave it a rub allover. Then I power washed it off.)
I won't say to do a test spot because if you try this you are going to loose the top layer of gel-coat! It's Acid! It eats fiberglass and You!
The outcome from my acid dip was very good. There is one spot about 2' by 1' on the Port seat in the cockpit that looks a little thin though...
The acid opened the closed pores of the gel-coat so now they needed to be sealed to prevent staining.
I should have used wax. I didn't! I went back to the hardware store and got industrial floor sealer! Why...? Because there was a bottle of industrial floor sealer stripper right beside it. And I was in a hurry and didn't care too much about how long it will last. (The boat was free...)
I used my garden sprayer and soft car wash brush again.
It look fabulous! I get all kinds of great comments on how "New" it looks form people at the yacht club and different marinas I've been to with it.
I do not suggest that anyone else try this technique! It's dangerous and can ruin your boat!
So far the floor sealer has lasted except ware I put my hand on it after spilling a bit of fuel on my hand. It has browned and come off a bit in that spot.
Some of the crazy things I did to the Siren start about here: http://forums.macgregor.sailboatowners.com/showthread.php?t=156758&page=15
Pictures are kind of self explanatory.
Remember NOT to try this at home! The raccoons hate it!
I now have $125 and allot of labor invested in this boat.
5
Schock Harbor 25 Sandusky, OH
I have used this stuff (StarBrite Deck Cleaner with PTEF) and it actually works quite well ... but one of the unexpected side effects is that it can leave the deck unexpectedly slippery after a while without washing. I'm not sure about the mechanism, but a good rinse with a hose seems to relieve the slipperiness. It seems as though Teflon is coming to the surface. I almost always cleaned my deck before racing and had no problems ... but when I didn't the deck was treacherous.
Another boat in our club had the same experience.
Anyone else had a similar experience with this?
I've used 3M's Non-Skid Deck Cleaner and a stiff but not too stiff scrub brush with good results. A little of the cleaner goes a long way. This is the labor intensive method.
If I had a power washer and a place to use it I would try that.
Dec 25, 2008
90
Catalina 34 St. Simons Island
Cleaning non-skid
Magic Clean. A little elbow grease but this stuff works. Best stuff I found so far.
The easiest and best way I've found is just to use a pressure washer. Be careful near hatches/portholes, etc. as you can blow water past the seals. Don't use bleach or other cleaners in the tank of the pressure washer in case some water leaks inside.
JamesG161
Feb 14, 2014
7,770
Hunter 430 Waveland, MS
Justin has best answer!
Cleaning depends on the stain or grim, just like on clothes.
Test in a small spot with samples of cleaning products.
Rust=Oxalic Acid, Naval Jelly (phosphoric acid), TSP, Wink, etc. most acids are in mild form and work on minerals too like Calcium and Magnessium (dried salt water)
Oil/Grease/Sun Tan lotion = 409, Mineral spirits, Mr. Clean, Magic eraser.
Black Algae = Swimming pool anti-algae in dilute water and soak time.
Faded or Hazy Gel Coat = Gel coat restoration
Scratching or wind hazing/abrasion = rubbing compound for jewelry, Paint
Pressure washing = not recommended because to much variation in pressure, time and spray tip. Some pressure washers can cut the mortar out of brick!!!
Black rubber marks from non-deck shoes= OMG get out the toothbrush or Magic eraser.
Good Rule...
Fiberglas is a soft material and so is paint.
So NEVER use abrasive powders or wire brushes to scrub or any material HARDER the Fibergas.
Jim...
May 20, 2004
151
C&C 26 Ghost Lake, Alberta
"Tilex with bleach" - $6 from Safeways.
Wet down the deck.
Spray on part of the deck and scrub with a boat brush.
Do the whole deck then rinse off with a power washer.
finding41,
How did you evict the Racoons? Ours haven't responded to polite requests.
Mar 20, 2012
3,983
...don't like pressure washing on a regular basis...... it will eventually ware the surface to a frazzle...
too much pressure can ruin any surface, but with a lower setting it will do no damage to the gelcoat or fittings/hardware, and technique/experience may play into this a bit also.
it can damage unfinished wood surfaces and soft material like canvas and lines... but this is where technique and experience come in to play...
a small affordable automotive type pressure washer that puts out around a 1000psi is a great tool for washing the boat... depending on where you keep your boat, it usually only needs a pressure washing once or twice a year.
and I dont care who you are, where you are, or how much effort you put into it, a pressure washer with a good chemical will clean nonskid better than any plastic brush and cleaner,
the only thing that does work better is a very fine stainless or copper brush and chemical... but then the effort is at least a hundred fold.....
the following pictures show what a fine stainless brush can do... with no damage to the gel coat.
I tried hand washing and brushing with awsome to remove the black, it didnt work... then I tried pressure washing and pre-soaking with harsher chemicals, and still did not get the results I was expecting, but when i used the stainless brush and awsome, it came right up... and it did not scratch or erode the gelcoat in any way.
I wont say you can use a coarse brush without damage, but a brush with fine bristles that can be drawn across your hand without damage can absolutely be used on gelcoat without damage.
(another harsh chemical that can be used on gelcoat, NOT paint, for cleaning the stubborn spots is easy off oven cleaner.... it will remove oxidation with very little effort.... any acid will remove tannin or rust stains)
I Like to pressure mine before winter to remove any built up dust/debris around the fittings, as this stuff holds moisture and it isnt good if it freezes and thaws repeatedly over the winter months
and I also like to pressure wash it in the late spring after the weather starts to turn, which removes any algea/moss that does begins to grow over the winter and early spring...
ive been doing it this way for many years with all my boats and ive never had problems with degradation of any parts of the boat or rigging, I firmly believe that by keeping the debris from around the hardware/fittings and windows, it helps keeps the bedding sealant doing its job....
it really doesnt matter if you use a brush or a pressure washer, but it does matter if its clean.
I have friends and seen other people who dont take the care they should to keep the "green or black" stuff from growing, and they have problems with water leaking from a failed bedding... i can honestly say I have never had a problem with a failed bedding, although this may be partially due to making sure the boat is a dry boat before I buy it....
zeehag
Mar 26, 2009
3,198
regular scrub brush and soapy water. keeps away the wasps also....... elbow grease and a bucket of love.
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I use Simple Green on the textured deck with a nylon bristle brush for dirt and grime. For the mildew use a micro-fiber rag. Wiping with the rag works wonders somehow and the brush is ineffective. Simple green does leave a residue, so rinse well and avoid using on gelcoat surfaces. I initially used Simple Green on the topsides and ruined several buffer pads getting the job done.
