Hot water heater -reset
TheTY
Jun 21, 2016
18
Hunter 380 Collingwood Ontario
I have a 2000 Hunter 380 and every time I unplug the. Plug back into shore power I have to take the electrical panel off the side of the water heater and push the reset button.
It is a Seaward Heater. Any suggestions?
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Seems like a bad reset switch. Do you have your HW breaker off when you plug in?
TheTY
Jun 21, 2016
18
I switch the breaker off when I unplug from shore power then back on when I plug back in. The reset switch is an idea. Thanks
Jun 6, 2006
6,990
???? if you switch off, unplug, do something interesting, plug back in, turn on the heater and then have to reset the breaker I'm not sure what you are resetting. Does the breaker trip when you turn it on after plugging in?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
check all your wire connections and make sure they are tight...including your ground wire
Beneteau 323 Annapolis MD
Is that a temperature sensitive or an AC load switch? Probably temp.
