Bob
A couple of weeks ago my engine overheated to the point where it peaked off the temp guage due to a broken belt.I have replaced the belt and chnged oil but the engine is now running very hot.When the engine is not under load it can run, so far as I can tell, indefinately without overheating but, when the trans is engaged and it runs at 2000 rpm for 40 - 50 minutes the temp goes up to 230 with no sign of stopping.I have checked the flow of fresh and raw water and that appears to be adequate. Have also checked the impellor which is fine.I am concerned that there is internal damage to the engine. Any suggestions or comments would be appreciated.
